wanted: S.C. Blade parts
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Topic: wanted: S.C. Blade parts
    Posted: 26 Mar 2010 at 12:22pm
looking for adjusting screws and the reversing plate. Both are bent. Thanks Ron
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2010 at 1:20pm
Don't know if this will work for ya ... My adjusting screws were bent (not real bad) and I took them out and being carful, using wood to not mess up the threads. was able to wedge it in the vice and using a long pipe or other instrument bent them back straight. Or the look straight and work now. ... ... ...the reversing plate would be a little different.
bucksnortAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bucksnortAC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2010 at 2:05pm
i have been thinking about having the reverse plate reproduced but making it like the front plate so you could push backwards at differant angles.  either way email me with your intrest in such a piece and i will check on pricing.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2010 at 2:56pm
I'M in on the reverse plate "Re-Pro" mines cracked again, I would be interested in your plan and cost
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2010 at 3:43pm
