616 with Onan
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Topic: 616 with Onan
    Posted: 17 Jan 2015 at 9:18pm
Picked up a nice 616 this week but when running especially at high rpm it leaks oil out of the oil filler/dipstick cap.It isn't over full so is there a crankcase breather or other problem? Thanks much.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2015 at 12:21pm
it says in the manual that the breather needs to be disassembled and cleaned every 200hr remove tubfrom air cleaner remove clamp oring cap and valve and baffle wash in solvant clean dry re assembble  claen and check for blockage on the breather tube from breather to the air cleaner
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2015 at 12:45pm
Thanks Hud. I'll try that tommorrow.
This page was generated in 0.289 seconds.
