Forum Home Forum Home > Allis Chalmers > Farm Equipment -Knowledge Base
To4b80 Turbo questions
studer automotive View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Topic: To4b80 Turbo questions
    Posted: 18 Mar 2024 at 3:07pm
I’m looking for a PN for a replacement to4b80. I came up with a 313099 PN off a borg Warner turbo , which replaced a tob490, which I believe is a replacement turbo for a d21 or 210/220. Im installing it on a d19 D so that’s entirely to big. Anybody have any input on this?
a-c 185-d y/r cab turbo soon
99 f-250 7.3 4x4
86 mustang5.0 owned since 8/93
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 9:57pm
It's been 45 years, but I'm pretty sure the D-21 and D-19 used the SAME turbo, which was a Thompson brand which later became a Rajay. I always thought that was interesting, but that D-262 couldn't stand much boost and the bigger size was just what it took to keep boost relatively low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 10:59pm
Interesting, I have a ray-junk turbo on my 19 now i’m looking to replace it with a b-w or garret. I found brand new borg Warner turbos for $450-$500. Thanks for the info dr.
99 f-250 7.3 4x4
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2025 at 9:09am
TO4B80's came with 2 different exhaust housings. The D19,190,200 all used the .69 A/R housing. The 7020 and some combines and industrial (gen sets) used the .58 A/R housing for about 2#'s more boost or the same boost at lower RPM.   The TO4 B90's were used on the 426 engines up to the 8000 series. They used 2 housings as well. Some combines, industrials, used the smaller .8 A/R  but most had the .96 A/R housing.  The smaller A/R housings forced more air to the turbine and spun it faster for more boost. The larger A/R's allowed some gases to escape around the turbine. The A/R # is usually stamped in the exhaust housing inside or on the radius. (some of the later China, perhaps, castings have no stampings)
Edited by tbran - 01 Feb 2025 at 9:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2025 at 12:20pm
Good info!!! Thanks
99 f-250 7.3 4x4
