To The "Bikers" |
Page 12> |
| Author | ||
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: To The "Bikers"Posted: 25 May 2021 at 8:13pm |
To those that straddle a "Harley", Gold Wing, or any other 2 wheeled "bike", do you consider a "TRIKE BIKE" of any form a "bike" ?? Been seeing a LOT of SPIDER bikes recently, but just this evening got behind an old "Trike Bike" with the 2 wheels in the rear
| Sponsored Links | ||
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35707 |
Posted: 26 May 2021 at 3:51am |
Answer is a solid "NO".
Are a "Trike" for a reason, do not ride the same where are actually more likely to have control issues at speed, lean a bike for corners, steer a trike and the Spyder units are no more than a three wheel convertible "Car" with a steering wheel. |
shameless dude
Posted: 26 May 2021 at 4:07am |
i want a "slingshot"!
shameless dude
we see alot of trikes traveling with the 2 wheelers
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9733 |
Posted: 26 May 2021 at 5:11am |
Two couples in our group switched to Slingshots. They still ride with us. |
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 26 May 2021 at 5:26am |
I made the mistake of buying a Trike in 2018. Biggest mistake I ever made. First time out for a ride nearly ran off the road on a curve. Their steering and handling is not meant to go around corners. Like driving an old lumber truck without power steering. Another fault is if a rear tire hits a Pot Hole, it has a tendency to want to throw you off the seat. It does 'look pretty' when parked though. G |
john(MI)
Posted: 26 May 2021 at 8:48am |
I'm thinkin a trike would be considered okay for a fellow rider. Perhaps there was a health or age issue which required them to switch. They still wanted to ride and be included, but could no longer do it on two wheels!
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12423 |
Posted: 26 May 2021 at 10:33am |
Agreed John. Had a good friend and coworker that switched to a trike when he and his wife got older. It ain't like he was cornering at 90mph anymore. He loved it, wished he'd done it earlier he said.
Thad in AR.
Posted: 26 May 2021 at 11:45am |
I live right in the heart of one of America’s best motorcycle destinations. They come from all over to ride our hills n curves. Trikes included. Some handle quite well
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6126 |
Posted: 26 May 2021 at 12:50pm |
Anything less than 4 wheels is considered a 'motorcycle' in basically all US jurisdictions. that includes a Morgan, if one happens to have one in their collection.
As an aside note, 3-wheel motor vehicles have been 'around' as long as, if not longer, than 2-wheelers. Handling issues... there's two facets to this... First, if you're driving a 'conversion'... a motorcycle converted to trike, there's some conversions that are substantially better, and some that are substantially worse, in both handling, and ride quality. GOOD conversions include making changes to the front end's rake and trail, because the motorcycle's 'leaning' dynamics in 'simple' conversions cease to exist, rendering that aspect of handling moot. Riders who learn the character of non-leaning trikes do fine, and those who don't, cannot. Second, 'handling' of a three wheeler is NOT going to be the same as a two wheeler OR a four wheeler. One cannot 'compare' them. If there's any point of comparison, it would be with either 1) a motorcycle with a sidecar or 2) an automobile missing one wheel. For what it's worth, when you're driving a car in a tight corner, you're actively transitioning it into a two, or three-wheel vehicle, as the weight transfers from lateral acceleration. Adding to that, when I'm riding MY motorcycles, and under extremely heavy braking, it is a ONE WHEEL vehicle- the rear tire has NO weight on it. When I accelerate, having the front wheel lift off is not inconceivable (but I'm rarely in that big of a hurry... after all, it IS a Goldwing travelling byways... not a GP racer on the Isle of Man TT... I met a guy three summers ago who built his using an independent rear suspension system around a Subaru differential, TIG welded double-wishbones, and motorcycle coil-over shocks. The shock towers' tops and control arm brackets were on a pivot which was linked to the frontend such that a turn in either direction yielded a corresponding 'lean'... and conversely, a corresponding lean would counter-steer the front wheel to 'want' to stay centered. As a result, in normal road driving, it leaned itself, and it's tires, as if it were a motorcycle. Rather than the popular 'car tire', he ran motorcycle tires on each side, lightweight wheels, and inboard (on the transaxle, not the hubs) disk brakes. Low unsprung weight, so it rode EXTREMELY well. He had an electric actuator and a gyroscopic sensor that once stopped, the motorcycle would pull itself to perpendicular position... even if it was parked on a hillside! He towed a one-wheel camping trailer, and his wife toured the country with him. He used to do it on two wheels, until an ear-infection left him with vertigo issues. He was kind enough to let me take it for a spin (with no trailer) and it was GREAT... almost forgot it was a 3-wheeler. As for Strykers and Slingshots, they're nothing new... the Morgan (noted previously) was first built in 1911, and has been on-and-off since then. If the modern three wheelers look too much like movie CGI or a popular basketball shoe for you, look at the classic redux that is finishing up this model's production run this year, and supposedly, preparing the NEXT version (it's apparently also available as an EV?). Three wheelers are rarely shunned from 'motorcycle' rides... because, as mentioned by others, they're very frequently operated by those who, for some reason, could not operate 2 wheelers anymore. The few group rides I go on, usually include sidecar rigs, three wheelers, chopped-up, bobbed, butchered, whatever homemade contraptions, dune buggies... and nobody has problems with it. in the same realm, some 'rides' may be 'brand-centric', the rides I'm on, aren't... Because... it's not about the type of machine, or the brand, or the vintage... It's about the scenery, smelling the flowers, enjoying the day, with people out doing the same.
Usually, there's four or five 'guide-riders' in the group who know the route, and the rest have NEVER been down this way. The restaurants and stores are happy to see us pull in, we never go away hungry, they never go home without good tips... and there's plenty of great scenery to photo, great stories to be told. |
Walker
Posted: 26 May 2021 at 1:04pm |
The third wheel is usually used to replace the leg that was lost on two wheels previously.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42275 |
Posted: 26 May 2021 at 1:05pm |
Some years back when out to Sturgis my son and I stopped for gas at a little place and just after we came in a group of Gold Wings a d Honda Trikes came in. Most acted like we were totally outsiders as he was riding a 52 Matchless G9 (500cc twin) and I had my 68 Norton N15cs (Matchless frame Atlas 750cc engine) , soon one guy came over and started talking to us then another - soon around 10 guys were all looking over our bikes until a couple snobs from the trikes came and dragged them away - saying those are just old junk and not like our classic machine .
So it seems the Wing and Trike crowd look down on other cyclists' and not the other way around . Heck I have had many Hamsters come over and check out my Nortons or sons other Matchless machines |
Boss Man
Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Posted: 26 May 2021 at 5:43pm |
Hell Coke, if I ran into you with my Goldwing and sidecar I'd be looking that snort-n Norton from top to bottom. I put the sidecar on to haul the kid when she was 4 years old. Have had a lot of Hardley riders come and check it out. When my dad couldn't hold his Wing up anymore they looked at trikes but didn't want that kind of payment in his 70's
DaveKamp
Posted: 26 May 2021 at 6:09pm |
That's an ignorant and unsubstantiated statement.
DMiller
Posted: 26 May 2021 at 7:32pm |
Wife wanted a Trike so she could ride (Drive) it too, took one for a test ride, she did NOT enjoy the ride and I got released from said looking.
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 26 May 2021 at 8:31pm |
I have a friend that has one. Has power steering and air conditioning. I asked him why the heck has it got AC? He said it's nice to have that cold air blowing on you when stopped at red lights.
They are not bikes. |
1957 WD45 dad's first AC
KJCHRIS
Posted: 26 May 2021 at 9:16pm |
I've several trikes ( Harley or Honda conversion) in the area. The riders are all 70 plus. I talked with 2 of them and their wives while getting gas. Then 1's wife laughed and said the real reason he got it was because she'd grown too much and he had trouble holding up 2 wheels w/her at stops. He's about 5' 8" maybe 170lbs, she's 5'6" maybe 250 lbs. He didn't say anything just looked at her. She said then why aren't we on the knucklehead, he just smiled.
IF I were to get different ride I'd look at a trike. For now will just keep my 2 old harley's , 1 is '01 and other is a '67.
shameless dude
Posted: 27 May 2021 at 12:26am |
the slingshots seats look comfy!
Thad in AR.
Posted: 27 May 2021 at 10:54am |
Kansas99
Joined: 26 Feb 2015 Location: W Kansas Points: 4868 |
Posted: 27 May 2021 at 11:41am |
I figured if I got the urge for a bike I’d have to get a trike. It’s not that I haven’t or can’t ride a bike but if I take some of the girls I date along I’m pretty sure 1 rear tire wouldn’t safely support and transport the load.
Joined: 11 Sep 2009 Location: illinois Points: 90921 |
Posted: 27 May 2021 at 12:39pm |
KANSAS !!!
![]() Edited by steve(ill) - 27 May 2021 at 12:40pm |
Posted: 27 May 2021 at 12:45pm |
Walker
Posted: 27 May 2021 at 1:15pm |
Edited by Walker - 27 May 2021 at 1:25pm |
Walker
Posted: 27 May 2021 at 1:53pm |
Look at the above photo and take a guess which part of you would come in contact first with the front of a car that just ran a stop sign. Now what were you saying about unsubstantiated and ignorant?
NDBirdman
Posted: 27 May 2021 at 3:43pm |
I ride both. Single seat 2 wheeler by myself. Trike when wife wants to go along. I have a bad back and arty-ritus, can't hold a 2 wheeler up with a passenger. It's a 3-wheel bike, don't give a fluck if it meets/passes anyone's muster about being a bike. Now... those 3 wheel'd snowmobiles.... there's a freaking joke...
DaveKamp
Posted: 27 May 2021 at 6:19pm |
what were you saying about unsubstantiated and ignorant? Again, That has absoutely no substantiation for your statement, and you've attempted to bolster it with fallacious support. Any imbacile can see that the above pictures are NOT representative of a modern three-wheel road tourer. Your suggestion of limb loss is totally fabricated- A simple observation of ridership populace proves otherwise. Go to any ride, any rally, or visit with any rider on a three-wheeler, and take a count as to how many of them are missing limbs. You'll find very few. You might find they have to walk with canes or walkers. You'll also find that MOST of them are generally older, and have been riding for well over half-a-century. Your statement is now notonly ignorant and unsubstantiated... it is disrespectful of what is, by nature, a generally elderly, mostly retired, and basically always a well-educated population. If they choose three-wheel touring as their form of enjoyment, it is not your, or anyone else's place to spew judgement upon them for doing so. You can choose your own. That old man, on his three-wheeler, very well may have been a medivac pilot in Vietnam, or a retired policeman, a surgeon, or a farmer.
Edited by DaveKamp - 27 May 2021 at 6:23pm |
Walker
Posted: 27 May 2021 at 6:59pm |
Aint gonna argue about it. Still say it's a bigger factor than evidently you can imagine. Maybe location plays a role this is touristy area here.
Tbone95
Posted: 28 May 2021 at 7:53am |
Geez-uz people......
NEVER green
Posted: 28 May 2021 at 8:21am |
I take my old Honda 350X on the county highway once in awhile and actually have gotten the two finger biker greeting a couple times, surprised me.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55312 |
Posted: 28 May 2021 at 5:28pm |
In defense of Walker, he made a joke, folks! If you dont like the joke, just sigh, and move on. Too much testy-ness in the air, these days!
![]() Does anyone know the difference between a Harley and a Hoover?
Page 12> |
