TL-14 ignition issue
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: TL-14 ignition issue
    Posted: 10 Dec 2012 at 11:23am
A buddy has a tl-14 with the gas 262. Hasn't ran in awhile. Put a new manifold and gaskets on it and soaked the carb and cleaned it out. Won't even attempt to start even with ether. Anyone have a schematic for the coil wiring? He got new points and condenser but needs to install. Any other ideas?
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2012 at 11:50am
I would say install the points and condenser first and go from there. As long as the wiring hasn't been messed with, it should fire and run. If still no spark, start at the Ignition switch with a test light and move forward from there. Should be able to find the problem..
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2012 at 8:43pm
He called me again and asked " is it true AC's are positive ground?" To which I replied laughing and said no wonder it won't run lol
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
This page was generated in 0.400 seconds.
