TL-12 brake system |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Topic: TL-12 brake systemPosted: 01 Aug 2023 at 7:48am |
Hey folks, I have my Tl-12 repower moving and driving. Got a new master cylinder but the wheel cylinders are leaking. Has anyone ever replaced these with a truck cylinder or another option? I have the oem cylinder part # 3014527 and come up with nothing online. There is a rebuild kit written in by hand in my parts book # 73014582. Minnpar shows its a good number but backordered. It is also a CNH construction # but shows unavailable. Any trucks use rockwell axles from the 50's? I was hoping to come up with something before tearing it apart and have it set a long time as i have been using the loader. These are a full floater axle so you have to pull the shaft and then the hub and bearings. Maybe I will have to be the guinea pig and retro fit something, but im looking for a solution first. Can wheel cylinder seals be ordered by size anywhere?
thanks
Edited by CAL(KS) - 01 Aug 2023 at 7:54am |
CAL(KS)
Posted: 01 Aug 2023 at 9:22am |
I contacted minnpar and they will have the seal kits in 3-4 weeks after i order them so I guess they order them from china? it is what it is i guess
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8978 |
Posted: 02 Aug 2023 at 10:47pm |
my 545B has truck wheel cylinders. Don't remember what they were. Did some size comparisons online to come up with it. They used what was commonly available in the day not some special one off just for them. I got them through rockauto.com for MUCH LESS than minn-parr.
nowaktj
Joined: 13 Dec 2009 Location: Elk River, MN Points: 735 |
Posted: 20 Sep 2024 at 5:08pm |
I've got the non-bug eyed version of the TL 12.
Edited by nowaktj - 21 Sep 2024 at 3:21pm |
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
