TL-10 Wheel Loader Goodyear 3.00 x 7 tire Drive |
Middlewest
Joined: 14 Aug 2018 Location: Dubuque Iowa Points: 3 |
Topic: TL-10 Wheel Loader Goodyear 3.00 x 7 tire DrivePosted: 15 Aug 2018 at 8:08am |
I have a TL-10 with an over 2600's serial number, and it started shaking badly and broke a motor mount. When we started taking it apart, there was a 3.00 x 7 goodyear smooth implement tire in a drum that drives the whole machine. It is torn up and I need to find a replacement. Thank you for any help. All the manuals that I see for sale stop at Serial # 2502.
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 15 Aug 2018 at 3:03pm |
i would call these guys, maby they can help
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42263 |
Posted: 16 Aug 2018 at 8:06am |
Motor couplings - used them on pumps up to 100 HP - was like a tire but made special for a drive where alignment was not perfect - flange attached to both shafts - then a ring bolted to flanges which anchored the rubber ring to flange.
Might try Herc U Lift in Mpls as they were a AC dealer and still in fork lift business |
Middlewest
Posted: 17 Sep 2018 at 4:58pm |
I have finally found a 3.50 x 7 heavy lug tire from Millers and we ground the lugs off and made it fit. Thank you all for suggestions.
CAL(KS)
Posted: 19 Sep 2018 at 3:06pm |
