Tires??
BiG210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BiG210 Quote  Post ReplyReply Direct Link To This Post Topic: Tires??
    Posted: 12 Feb 2012 at 8:51am
Can I run a 6ply and a 10 ply on the front of 8070 and not hurt the front u joints thay are 18.4-26's two dif. makes. also none raidel's
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 8:55am
I don't know why it would hurt the U joints. Might tear up the differential if the size is much different , making it slip all the time.
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 9:07am
If the rolling diameter of them are the same you should be ok. But if they are different diameters then you will hurt the differential and such! Need matched set of tires on any FWA tractor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BiG210 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 8:29pm
Thanks I thougnt that if one is 6 ply and one 10 the 6 would be softer and flex more under a hard pull.
EricSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 8:42pm
Probally would flex a little more you could run more air in the 6 ply.
This page was generated in 0.115 seconds.
