Tires
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Topic: Tires
    Posted: 26 Aug 2020 at 3:47pm
I have a new tire on a WC rim which.is a 12 x 4 28. Will that fit on a WD rim which is a 14 x6 28 ?
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 4:59pm
So just to correct your tire terminology. Your tire is 12.4 x 28. That is 12.4 in wide on 28 inch rim diameter. I think the next size may be 13.6 by 28 and then 14.9 by 28. Then you have to consider the rim width. That could be 11 in, 12 in, 13 in and so on. So you have to know your rim width and decide what you want. 14.9 by 28 works well on a rim that is 13 wide. It will fit a rim that is only 12” wide but starts to look funny - too rounded on top. Tire footprint not as good.
Edited by Ed (Ont) - 26 Aug 2020 at 5:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 5:07pm
how wide are the RIMS ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 6:50pm
Sorry the WD rim is 14.9x28 so will the 12.4 28 fit the 14.9x28 rim.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 7:05pm
You can put them on those rims. Put a new tube in the tire. When I owned the tire shop, guys would go to salvage lots and buy decent used tires maybe a size smaller that originally came on the tractor. I always explained they may not look quite right. If you use the old stretched out tube on a smaller rim, there is a very good chance the tube will wrinkle no matter how many times you let the air out of it.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 7:21pm
Depends on what's on the other side of the tractor.  It'll fit on that rim, but you want the same size tires on both sides.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2020 at 7:06am
There is no 14.9-28 rim. That is the tire size. Your rim could be anywhere from 10 inches wide to 15 inches wide.
 A 12.4 tire on a WD would look anemic in my opinion, and probably not a good thing if the other tire is a 14.9 .
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2020 at 9:54am
Thanks for the information guys very much appreciated.
This page was generated in 0.313 seconds.
