tire question
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Topic: tire question
    Posted: 07 Jan 2014 at 8:32pm
I am wanting to put different tires on my puller. Right now I have 16.9x26 firestones and am wanting to go to something taller. My question is would a Wd45 with a stock ring and pinion and 315 ci turn 36" or 38" tall tire in a 5500lb class in 1st gear without powering out. Im thinking either 13.6 0r 14.9 wide.
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2014 at 8:54pm
15.5-38 Firestone 151 on 14" or 15" rims  where are you from and where do you pull
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2014 at 9:03pm
My 17 can spin 18.4x38 bfg in second with 65 ci less than you have. I'd say you shouldn't have a problem.
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2014 at 9:04pm
Im from central illinois and pull mainly in brush pulls around the area but im always looking for more. I just wasnt sure if i could turn that tall of a tire without powering out or not
Orange1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange1 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2014 at 9:28pm
I pull in central il with wd 45 and 15.5 38 151's with 240ci with out much problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2014 at 9:32pm
Are you guys running the normal Wd45 ring and pinion or tbe diesel ring and pinion and what weight classes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange1 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2014 at 9:53pm
Stock 45 rear end 4000 - 5500 lb class
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2014 at 10:03pm
Roughly what mph is your ground speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2014 at 5:31am
I run a wc stock ring and pinion we have a 4 mph. class an i can run 4.2 in 1st i know how the sled monitor works on the sled works so i drive a little different than some of the other drivers do
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2014 at 7:30am
Thats for the help guys i was concerned that if i ran that large of a tire i might snuf it and make myself look like a fool
This page was generated in 0.482 seconds.
