Tire pressure?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Topic: Tire pressure?
    Posted: 18 May 2023 at 3:16pm
What do you all run for air pressure in 18.4 radial singles? Has fluid. Were at 20. Even at 24 they squat plenty. Usually has duals. But removed for liquid side dress. Firestone R1 23 deg. One 2 inch inner wt each side. 8070 TIA
Edited by SteveM C/IL - 18 May 2023 at 3:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 4:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 4:13pm
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 6:01pm
7045 at 15,500 lbs sidedressing I’m at 20
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 10:39pm
At 20 singled out they looked like they bulged 4in in sidewall and had about 2 1/2 feet of tread on the ground. I went to 24 and the lugs on the ground are touching all the way to the outer edge. That's what the tire guy told me they should do when I bought them.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2023 at 9:44am
On my brothers 7060 (with duals) we run in the field at 12-15 psi but when we run a 5 shank 3 point subsoiler we run 24 psi to keep it from working the sidewalls.
Now my dad has a John Deere 4255 that he sprays with singles and we run about 25 psi or 3 lugs on the ground…
