tire preference |
Fields
Joined: 25 Apr 2011 Location: Reedsburg, Wi Points: 359 |
Topic: tire preferencePosted: 18 Nov 2015 at 12:34pm |
I've been running whatever cheap to buy tire i can. The first 15.5-38s were firestone 45 deg. Then goodyear traction torque , I have pulled a set of 13.6-38 cut goodyears and have done well. But most classes don't allow cut tires. My colection of availible tires to try are 14.9-38 goodyear traction torque, firestone heavy duty field and road 15.5-38, and a pair of Armstrong 15.5-38 tires 30 degree. this next year im going to swap and or switch at least 3 sets of tires on 3 differn't tractors. To see if i can inprove or meet class rules.
Larry(OH)
Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1580 |
Posted: 18 Nov 2015 at 4:58am |
Never see the long bar short bars do anygood around here. I like the Firestone F&R
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
mike a
Posted: 17 Nov 2015 at 10:34pm |
old worn out road sharp 45 degree stones,about 6-7 psi,15.5x38,be ready for traction!
TennMatt1
Joined: 12 Oct 2015 Location: Southern KY Points: 71 |
Posted: 17 Nov 2015 at 9:55pm |
It really depends on track conditions but a hard tire is far better for pulling tractor. New and or soft tire lugs roll really bad then flick up the dirt and that piles up in front of the sled. Ive never till now heard of a new tire pulling better. I had a set on my tractor when I got it and actually watched a video of them in action versus a old decrepit wore out tire..The old tire pulled way further. unless your in mud or in a rice and cane feild there's no need for a lug because you don't wanna dig down,it lowers your pulling point. The list goes on and on. My preference personally would be the safeway because of tread pattern. Those 23's pull good.
1954 WD45
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4063 |
Posted: 17 Nov 2015 at 7:29pm |
my experiance is that old hard tires just dont get traction like new soft rubber dosnt matter if you are in the field or on the track you can make tires hard with more air or wider rims to pull that side wall out and flatten the tread dont know what rules say about rims
BennyLumpkin
Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
Posted: 17 Nov 2015 at 6:16pm |
I don't like how long bar shirt bar pull. The 14.9 aspect is nice but the safemarks are good pullers. That's what was on my WC puller. .13.6x38 topcuts
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
alan-nj
Joined: 12 Sep 2009 Location: oxford, nj Points: 847 |
Posted: 17 Nov 2015 at 4:46pm |
opinions.....which tire would you prefer for pulling? and why?
first pic is a 13.6 safemark; old tire, hard, 23 degree 2nd pic is a 14.9 titan short bar / long bar, pretty hard, not as old as safemark if you prefer the titan because its a 14.9, which would you prefer if they were both same size? . ![]() . ![]() . |
If ignorance is bliss, than happy days are here again.
