Tire options D12
AveryD12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Topic: Tire options D12
    Posted: 05 Feb 2025 at 8:55am
Since repairing the front wheel on my D12 series 3 I have decided to replace the tires instead of reinstalling the old ones. In the post a few days ago about wheel repair options Gary posted a reply that included a link (thanks again) with info and a picture of a D12 series 3. I like the looks of the tires in the picture much better than the tires on my D12. I have been trying to find out the tire size…with no luck. I found a couple of pictures online of D12’s and the tire size is obviously different. I will try to post both pictures. If anyone can help identify the larger tire size … many thanks. Currently I have 5:00-15
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 9:20am
The picture on the right are 14.9 x 24's, which was an OPTION on the later series. D-10-12.  I just installed a set of 13.6 x 24's on my D-10 which replaced a pair of 11.2 x 24's. A big difference for sure. The larger tires may cause you to run the wheels out from the fender one setting (2 inches) to avoid contact.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 10:19am
Thanks Dr. But I was referring to the front tires. I have 14.9-24 on the rear but like the looks of the larger front tires
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 10:23am
I'll have to look in my book when I get home. I'm thinking at 7.50 x 15 or 16 ??
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 11:42am
I have similar GM rims on my WD project as seen on the right photo. Tire size is 7.50x15
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 1:54pm
I have 15” wheels. Would like to know if 7:50-15 would be ok before buying them.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 2:15pm
Avery
My D-12 Series III has 14-9 X 24 on the Rear and 7:50-16 on the 'car style' Rims on the front. I believe that was the size available from the Factory.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 3:19pm
I’ve read somewhere there were tire size options from the factory. All the specifics I can find about the front tire option sizes were the 5:00-15 and something smaller (I can’t remember the smaller size). I would like to go with the larger size but don’t want to buy something that won’t fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 3:23pm
look at the clearance between your present tire and the vertical spindle tube.. That can vary depending on what RIMS you have and the tire size... going from  5 inch to 7.5 inch will put you about 1.25 inch CLOSER to the spindle tube..... Do you have enough clearance ?
Edited by steve(ill) - 05 Feb 2025 at 3:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 3:27pm
A good tire man can tell you what WIDTH of rim you need for a 6:50 x 15 or 7:50 x 15 tire to go on your existing wheel. You should be able to measure the rim width with a piece of wire bending it to measure like a calipers and remember if it measures 4 1/4" outside it is a 4 inch rim as you are measuring from the outside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 4:22pm
Thanks. I’m about 75 miles from the tractor now. Will be back home first part of next week. I will check it out then
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 4:48pm
Avery
.There were a large number of front Tire sizes for the D-10 and D-12.
Here are most of them:
4.00 X 15, 5.00 X 15, 5.50 X 15, 6.40 X 15, 7.60 X 15
5.50 X 16, 6.00 X 16.
   Of course every body knows you have to use the appropriate Rim ( similar to what would have been supplied by the Factory EG. the Car Style Rim )
That way the Tire won't rub on the Steering Spindle.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 6:59pm
I looked at my literature and they call out a 7:60 x 15 for that balloon type tire. The wheel offset has to be different I guess to keep the tire from rubbing on the spindle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 7:26pm
i think he is trying to get the BIGGEST tire he can, and use the 15 inch RIMS that he has now...
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 8:09pm
Here is a link to a similar Front Wheel discussion on this Forum.
PaulB mentions an Old Chrysler 15" is a good match.
G
https://www.allischalmers.com/forum/wanted-d10-d12-series-3-front-rims_topic202289.html
bozrae View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2025 at 7:57am
Here's a pic for a D12 series 3 operators manual.
D15D, D17G, 170G, 175D, and two 5050FWA
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2025 at 8:45am
Thanks everyone. After seeing the info I looked at AGCO site for D12….. I guess I should have started there. I see the larger tire size calls for a wider wheel but also found on the AGCO parts site for D12 calls for a different hub for the wider wheel. I don’t want to get into all that change just for the looks of a bigger tire. Like Steve said just looking for a bigger tire that would work with the wheel I have and not rub the spindle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2025 at 12:18pm
you have a 5 x 15 tire now... I would think you could go to 5.5 or 6 inch without problems..( if such a size is even available)... 7.5 might be a little big for the rim..
Edited by steve(ill) - 07 Feb 2025 at 12:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2025 at 12:32pm
multi rib, not 3 rib
Edited by steve(ill) - 07 Feb 2025 at 12:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AveryD12 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2025 at 1:37pm
I’ll ask at the tire shop before I buy. I’m not even sure what the next available tire size is above 5:00-15
Thanks
Avery
