Tire guage
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Topic: Tire guage
    Posted: 10 Aug 2026 at 8:47am
Haven't delt with checking air in a tire lately that has calcium but rember it as destructive to any guage. How do you do it?
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 9:14am
Valve stem straight up top. Put a little air in tire then check
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 9:15am
I dont run any calcium. Ive git methanol in mine. I made a checker for tires with fluid that uses regular pressure guages. Doesnt hurt them even if they get fliud in them
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 11:25am
Thanks for the tip Ryan! All of my D 15 tires have water in them. Next time I'll try adding a little air before checking
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 11:43am
Stem at the top and use a gauge rated for liquid in tires.  Here are three and there are others rated for air/water filled Ag tires.
Milton S-928W
Slime 2007-A
Tru-Flate 17-517
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 12:22pm
You cna buy a gauge rated for fluid. They usually have a little ball on the tip of the stem. I have one but still turn the stem to the top.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 1:11pm
If you can wash the gauge off after use and spray it with wd40 0r something better or at least spray it with wd40 even if you can't wash it. If tires are full I have even parked on a hill to tip fluid away from the stem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 1:18pm
I put stem up top,jack wheel off ground and give a couple shots of air with plain old air chuck. After that I use the Milton inflator gauge. I change valve cores every 2 yrs part of the reason for jacking up. They get ate up and you find yourself digging out corroded pieces if left too long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 1:50pm
Thanks Jim. I ordered myself the Milton gauge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2026 at 8:04am
Received my Milton S 928 tire gauge today. Haven't used it yet but seems well made. Even claims Made in USA !
