tire cut question
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: tire cut question
    Posted: 31 Oct 2013 at 5:58am
found a set of Firestone F&R 15.5x38 with this cut. i  know nothing about tire cutting. this is more than topcut right?  i have had my eyes open for tires for my puller that is probably a year out from completion, but i know good ones are hard to come by.    so my question is, what are you opinions on these, i was really wanting uncut as i wanted to be Natpa DIv2 legal but these arnt a bad price.  may jump on them and see what happens
Edited by CAL(KS) - 31 Oct 2013 at 5:59am
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2013 at 7:34am
They would be the same if you had a brand new tire? I think they are top cut though
Charlie
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2013 at 7:52am
Nice top cut, better than a new tire, if cut correctly they will have a nice angle on them where they will BITE the track! Looks as if the front of the lug has been cut also, not sure if that will be considered "Top Cut".
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
The Other Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Other Orange Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2013 at 7:53am
That is a common style cut front and top cut. Looks like there is alot of tread left that can be good and bad. Around my area uncut 151s are priced higher than full cut 151s due to the demand for 15.5 top cut. Because if you run full cut you will be pulling against 18.4s. 151s are great one of the best top cut tire but when you start cutting the front edge it levels the playing feild for other brands. I would check tire rules around you. If you choose top cut you can pull NATPA 2TC and USAP farmstock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2013 at 9:08am
yes, that is what i was wondering if that would be considered full cut, not just top cut.  thanks for the opinions guys
the club i hope to pull in uses Natpa rules
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2013 at 6:05pm
Where are these located?? I could use a different set for one of my AC Pullers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2013 at 8:47pm
well....i dont mean to be rude but i havn't decided whether to take them yet so id rather not say.. if you like i will send you the contact info if i decide not to purchase.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2013 at 8:53pm
That would be OK fine. Thought you couldn't use them because of the top and front sharpening.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2013 at 9:01pm
i can... just not sure if jumping straight to div 3 is what i want to do Confused
