Tire balancing beads??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Tire balancing beads??
    Posted: 09 Jul 2023 at 10:37am
So this talk with the balancing beads- ive been changing more impliment / tractor tires at my shop, now wanting to put new tires on my 3500 Dodge- so Esco has a chart that says how many ounces of beads to put in per tire size,,, now you just throw these beads in loose ? Seen some in a packet,, how does this work and what is better? Kinda hard to make sence on how this system works ,,
Edited by DougG - 09 Jul 2023 at 10:37am
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 11:17am
I put them in loose, was told they would seek their own balance. I put all new tires on my Chevy 3500 dually, put beads in all tires and never had an issue.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 12:44pm
Make certain you install the correct valve stem cores for these or the first time you add air to the tires, the original type stems will leak slowly.
That's All Folks!
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 1:09pm
Put centramatics on it,few more bucks,get 30 to 50% more tire life, I ran them on my Peterbilts and Freightliners, literally put millions of miles on them without one failure,in the process of getting them for my one ton dually.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 1:25pm
we used them at work, came in several weight packets, just tossed the correct amount in the tire before seating the bead. They wear their way out of the pack in just a few minutes and then were free to find their balance.
Edited by JoeM(GA) - 09 Jul 2023 at 1:25pm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2023 at 1:09am
some use sand too. buddy of mine used to sell the ones that went outside the wheel on the back of them, was a plastic circle with balls in them. i've used the sand before and always worked well. different ounces for different sized tires like the balls. it all goes in loose.
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2023 at 12:46am
Another vote for the Centramatics.
I have been running Centramatics and good old genuine 7.50-16 Bias tires for years on my 1985 F-350.
The only time I would ever use another radial tire is if I got caught in a situation where that was all I could get.
Believe me or not, I have a set of four Power King Super Traction across the rear that are currently some over 100,000 miles and still have lots of life in them.
My truck rides and drives like an air-ride big truck.
Two things I will say about Centramatics.
1. Never mix any sort of internal gimmick wheel balancing trick with Centramatics as the two will act against each other.
2. Before you install the Centramatics on rear duals, have yourself a set of quality braided stainless air valve extensions on hand as you will never be able to access the inside wheels otherwise, no matter what kind of air chuck you try.(with duals, you should have these anyway; I recently had the devils own time airing the inside tires on one of my early Dodge/Cummins with bone stock wheels and I have a drawer full of various long air chucks)
As for any of the inside-the-tire balancing gimmicks, I have seen everything used from a pint of anti-freeze to a dozen golf balls and everything in between.
If you use the store-bought bags, whether sand or beads, just toss the un-opened bags inside as the bag will deteriorate and let the contents loose.
A word of warning about using sand or any of the so-called beads, they are all silica; and, unless you wish to die a coal miners death, or wish it upon your tire fixer guy, just don't use the stuff as it will turn to powder and blow out of there and straight into your lungs when you break loose the beads.
Nowadays, balancing tires/wheels is pretty much a marketing gimmick as they are so precise as to not need it at all; just run them; and, if you feel a vibration, get yourself a set of Centramatics and be done with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2023 at 7:40am
Thanks for the advice! I do like the real time experience
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2023 at 11:01am
Valve Stem Extenders
This is just an example; the amount of choices is overwhelming.
For a 1-ton steel-wheel DRW, 7-inch extenders are long enough but just barely; 12-inch are better.
Instead of using the useless clamp-on clips provided, I fabricated semi-permanent brackets that are secured by one of the axle-flange bolts; to do this, you will need some Schraeder nuts that fit the threads where the valve cap goes.
Also in that set I linked to, I use the more-than-90° elbows on the outside wheels; thus, I can air straight on instead of having to use the "pull against" side of the air chuck.
I just used the linked-to kit as example as it showed both the braided extenders and the little rigid extenders; you can find better deals by buying a pack of four 12-inch extenders and buying a pack of the little sharp elbows.
Although only two long extensions are necessary, I recommend getting four and putting the extras somewhere inside the truck where you can find them; maybe tape them to the jack handle; as, some day years from now one of them will begin leaking.
Before you install them, screw all them together and attach them to a pressurized tire and give them a thorough soapy-water test for leaks to be certain that none of them have any problems straight out of the box; sadly, in this buy-by-the-container-load world we live in, we, the consumers, have became the quality control and any manufacturing problems are ours to find after the fact.
The Centramatics on my 1985 DRW F-350 have 16 holes as the later Fords have some weird Communist bolt-pattern slightly different from the good old fit-everything-8-lug 8-on-6-1/2 pattern; you orient them to fit your bolt pattern.
The rears for the duals are pretty much flat and fit between the wheels.
The fronts are shaped like the inside of the wheel.
One thing to keep in mind with any sort of tire/wheel add-ons, including your shiny new valve extenders and expensive Centramatics, if you are one of those take-it-to-the-tire-idiots-and-leave-it kind of people, being mostly idiots, they will lose your extenders and bend up your Centramatics and toss them aside and when you come pick up your truck you will leave without all your nice stuff --- better to never allow anyone but yourself to mess with your wheels --- ignore this bit of advice at your peril.
As I already said elsewhere, new tires/wheels themselves are so precision made as to not need any balancing --- tire/wheel balancing new stuff is just a marketing gimmick --- same goes for "rotating" tires/wheels --- bolt them on and leave them be; rotating just moves problems around and gives the tire shop guys opportunity to con you in to all sorts of extra expenses.
Look at it this way; if you have a certain wheel position that tends to wear the tires funny, by "rotating", pretty soon you are going to have all four of your tires looking funny.
Fifty-some years in the tire business and the best way to make a happy customer un-happy is to rotate his wheels; before any rotations, he is all "those tires roll as smooth as silk"; after rotation he is all "something is not right; I feel a lot of vibration" = best to leave them alone.
This is where Centramatics really shine = they will cure any tendency a vehicle may have to "cup" or "dip" the tread and will even smooth out already damaged tires.
If you have a tire that is scalloped and dipped, installing a Centramatic will begin evening out the dips and imperfections and true up that tire such that, while it will still have the unevenness in look, it will no longer buck like a mule.
Edited by BuckSkin - 15 Jul 2023 at 11:09am
This page was generated in 1.168 seconds.
