Tips & Tricks For Gaskets
Deer hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deer hunter Quote  Post ReplyReply Direct Link To This Post Topic: Tips & Tricks For Gaskets
    Posted: 03 Mar 2011 at 5:35pm
Looking for advice on gasket installation for a D17 engine. I plan on changing most all the gaskets on it. Do i use sealer on all of them or just some?  If so what sealer  works best? I will be pulling the engine out and put it on an engine stand to do this I want to do it right.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 7:59pm
I use HI TACK  sealer from Fel -Pro I believe , its in a can has a brush and works great , doesnt set up real fast and easy to work with but does a great job of sealing ; dont use nothing on the head gasket unless the instructions say so
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 9:27pm
 The best tip I know of is to make sure the mating surfaces are clean.
I have used a product called "indian head" that is a thin gasket sealer. Don't use this on something like a valve cover gasket that you may have to remove again though. That stuff sticks like glue and is very hard to remove once it sets up.
I have used copper coat on head gaskets before. I don't know if it helps or not but everything I used it on didn't leak.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 10:02pm
i use Perma-tex HI-Tack spray on sealer works great, also high temp spray on for head gaskets
swit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swit Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 3:07am
loc tight makes a good product called gasket elimantor ive used it very lightly with a gasket works well
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 6:41am
Indian Head Gasket Shellac. Comes in bottle with a cotton ball attached to the lid for application. I use the same stuff, especially on cork gaskets. I dont use silicone, silicone wasnt around when these tractors were built.
1968 D15D,1962 D19D
sks72107 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sks72107 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 6:55am
where can a fella get this indian head gasket shellac??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 6:56am
Try NAPA. I'm pretty sure I've seen it there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 7:00am
Yup, my local carquest and autovalue stores carry it in stock. Probably for me, I dont think anyone else uses it. I first came across it when restoring my JD 720 Diesel. The head gasket on those is stamped steel, and the FSM tells you to coat both sides with gasket shellac before assembly. This fills minor pitting that the steel gasket would seal on.
Edited by DonDittmar - 04 Mar 2011 at 7:01am
1968 D15D,1962 D19D
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 7:12am
I will glue the valve cover gasket to the valve cover, let dry and that holds it in place when you put on the valve cover. If you have to readjust the valves when hot or after a few hours of operation then I will glue the bottem of the gasket to the head after the surfaces are well cleaned. If at a latter point in time if the valve cover has to be romoved I  put on a new gasket if nessary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 7:17am
On tin head gaskets as on the old flatheads I use copper coat, some guys used to spray paint the head and block seal areas with aluminized paint and did fairly well with that.  For general purpose I use either HiTack or Indian Head as they seem to do the best.  I do avoid silicone sealants, they tend to be excessive and most are not impervious to oils or the chemicals added to oils, only GM dealer supplied black silicone does well in this category but it flashes off in less than 5 minutes working time so you have to be really quick and it has to be really clean and dry.
