tips on increasing horsepower on AC-B
hermin's dad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hermin's dad Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2011 at 10:57am
thanks dick
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 8:06am
The quickest and maybe cheapest would be bolt on a WD45 or D15II (best choice) carb to the existing manifold and if the hole in the manifold isn't as big as the carb throttle plate...open it up to match. You will see a difference and leave air cleaner off.
How do you match up a WD45 carb to a B manifold since the bolt spacing is different? Or are you suggesting to widen the holes to get it to work?
Would a WD Carb work since the early ones were the same bolt spacing?
Charlie
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 11:27am
I know a lot of pullers scream big carb big carb. You can get all air mixed fuel your engine can use even with the largest bore and stroke you can fit in the engine out of the carburetor that came with the tractor. With a few modifications. Some of the places I pulled every thing you could see with your eyes had to be stock. To get what I needed in a carburetor I did with the existing carburetor without changing the outside. It just takes some trial and testing. You can mount as big of carburetor on as you can find and still can not get any more fuel mixed air into the engine than you can get thru the manifold and valves.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 6:35pm
Originally posted by hermin's dad hermin's dad wrote:
tractor runs has good oil pressure,seems strong   have extra head need specs on milling to raise compression,possible port and polish if it makes any sense  kid just went to local grange fair dont know about any governing body  just wants to have fun at local events
If you're talking about the Centre County Grange Fair, he cant pull there anyways....lowest class we pull is 4000 pounds but The Antique Show at Penns Cave does as low as 2500. As far as alot of pulls around this area go by the pulling rules at the CPTPA webpage http://cptpa.yolasite.com/
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 7:42pm
He could always add about 1500 lbs of weight and pull with the 4000 class. Never know what might happen but he probably won't spin out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 8:35pm
Not enough grunt in that lil B.....I'm regularly embarrassed with my WC.....last week I got a whopping 44 feet....its engine build time.......
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
This page was generated in 0.073 seconds.
