Tips for pulling the head (160)
Fellenz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Topic: Tips for pulling the head (160)
    Posted: 19 Oct 2010 at 5:03pm
Hello,
I'm pulling the head to troubleshoot engine problems on this tractor.
Following the I&T book it appears I have done everything necessary to prepare the head for removal. I have removed all the necessary lines, removed all the head nuts, etc.
I tried to pick it with an engine crane and a sling but it seems to be stuck pretty well and I didn't want to put too much force on it until I consulted the experts for advice.
This is my first time doing any major work on a diesel engine so I'm unsure what exactly I should be expecting. Advice?
Thanks,
Erik
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 5:22pm
did you pull the studs if your not picking up 100% stright they will pinch and be a pain.
160 CA 920diesel 5020 HD-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 5:55pm
No I did not pull the studs, what would be the best method for pulling them out?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 6:38pm
a stud remover  or 2 nuts jamed together.  If you dont have the puller dont mess with them mainly due to you will have to torque them back into place.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 7:57pm
dont pull the studs, you just need to break the gasket loose. creative use with a prybar will release it. good luck.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 4:42am
I always use a short (12") or so length of 2X4 and a hammer to break loose heads that are stuck. Use it in several places around the head and it will free it up . HTH  God Bless.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 6:42am
Remove the injectors from the head before removing if it is a direct injection style.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 9:44am
Thanks everyone for the advice. I'll grab a small prybar and give it a go.
Thanks,
Erik
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 10:04am
Yea, I remember he already had the injectors out. Excellent point though Dr.
This page was generated in 0.139 seconds.
