Tips for 16HP Kohler Build
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Tips for 16HP Kohler Build
    Posted: 23 Feb 2017 at 5:59pm
I am rebuilding a 16HP Kohler K341 for my 716 Six Speed for stock altered pulling. I can go to .060 overbore. Any tips for rebuilding this puppy to get the most out of it? Better cam? Thanks for the advice!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 6:51pm
Unsure of rebuilding that far over - but if you need a couple more engines I have 2 that I would sell -
 I rebuilt 1 to 20 over with new crank - other was rebuilt stock bore but the balance gear broke and broke the dipper on the rod
 Ended up replacing the engines with a Honda V - 18 Hp in my New Holland S16
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2017 at 8:48am
I'm imagining shaving about 1/8" off of the head to raise the compression, or adding to piston height would be better yet.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2017 at 9:37am
midwest supercub has lots of high performance   k motor parts ( internals that will stay together)  or brian millers a1 machine  is also a good sourse o knowlage  on kohler puller engines
This page was generated in 0.180 seconds.
