Timing, marks use F25 degree or otherline on fly
boscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Topic: Timing, marks use F25 degree or otherline on fly
    Posted: 04 Feb 2010 at 10:51pm
My flywheel has a line marked on it ,also a line with the  letter F and 25 degree sign. Which do you use to time engine, what  is each line for?  Which is TDC? It is on a D17 1959 model thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 10:54pm
Wide open throttle time at the "F-25" mark with a timing light.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 11:05pm
I had it running well and it wont start at all, power to everything, coil, points, gets gas. So with engine off do I start at the one other line which is TDC?   #1cyl pressure pushing out finger, line is in sight hole ,line up rotor with #1 rotor post , tighten back down, points about ready to open,should start ?. I have a spray coupe with a volkswagon engine and if the points arent exact it WILL NOT RUN AT ALL. Maybe these tractors are point sensative?  what am I doing wrong?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 11:09pm
 The blank "line" is TDC..........F-25 is 25 degrees before TDC. Points to be set at .020".
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2010 at 11:12pm
Thank you Doc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2010 at 3:29pm
I got it running again today, I re-timed it and it started but kinda rough so I loosened the dist while running and turned counter clockwise and it now literally purrrs, It sounds great. I hope that doesnt hurt it to adjust when running.
