Time to settle an argument…….. |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8342 |
Topic: Time to settle an argument……..Posted: 07 Feb 2026 at 5:53pm |
Concerning the aspects of changing a dually pickup, to single rear wheel. Some have claimed there are spacers to remove, change brakes, etc. I say, if you want to keep the flaired fenders, just remove the tires from the inside dual, remount the inside rim, then remount the outer tire and rim just like before. The now single rear tires will set wider than the steer axle, but so what? Am I mistaken?
Joined: 11 Sep 2009 Location: illinois Points: 89987 |
Posted: 07 Feb 2026 at 6:46pm |
why would you remount the rims without tires on them ?? ... i would think you would want to move the rear tires INWARD a little bit ? ............ are you thinking the inner rim will protect the brake / caliper ?
Edited by steve(ill) - 07 Feb 2026 at 6:55pm |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35312 |
Posted: 07 Feb 2026 at 8:09pm |
Are no special spacers, axle housings are different, dually Pickup Wide spread rear is Wider and has longer axle shafts. Put single wheels on it will remain wide. To compensate for Inner dual tire from riding too close to springs.
The other concern is you now Offset the load to the wheel bearings. Dual Hubs the tires support equall mass against centerline of Hub, same is true for a single rear wheel axle hub. Rear studs on my SD 250 are same length as for dually. Edited by DMiller - 07 Feb 2026 at 8:11pm |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42194 |
Posted: 19 hours 8 minutes ago at 2:43pm |
Seems if you go to rims for a single tire rear , the load would center on bearings and the clearances would be good , using the duel rims over to single would create offset which might become a issue .
Posted: 17 hours 45 minutes ago at 4:06pm |
standard rims off a single tire axle would probably look good and be best... but now you got rims that are not interchangeble front and rear...
Lars(wi)
Posted: 12 hours 32 minutes ago at 9:19pm |
Thanks everyone, yes I imagine a guy could use ‘super singles’.
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 142 |
Posted: 7 hours 31 minutes ago at 2:20am |
My brother did this on a Dodge years ago. Take off all the offset wheels and the spacers from the front axle and put on single wheels all around, he used white spoke aftermarket wheels. He had a flatbed, so when done it looked no different than a 3/4 ton. This only works with a one ton pickup, if you have a one ton cab and chassis it has a narrow rear axle.
Ted |
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4919 |
Posted: 2 hours 4 minutes ago at 7:47am |
There’s a young man here running super singles, I questioned him at the fuel pump one time, he said it’s a scary ride in the rain, and useless on any thing but asphalt
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1578 |
Posted: 26 minutes ago at 9:25am |
Why would you want to do that? Just curious.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5228 |
Posted: 17 minutes ago at 9:34am |
Those that want to hide from DOT want single wheels all around. Anything that has Duals is almost always over 10,000 GVW and automatically need at least an annual FMCSA inspection, which very few have = Easy ticket.
