Time to settle an argument……..
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Time to settle an argument……..
    Posted: 07 Feb 2026 at 5:53pm
Concerning the aspects of changing a dually pickup, to single rear wheel. Some have claimed there are spacers to remove, change brakes, etc. I say, if you want to keep the flaired fenders, just remove the tires from the inside dual, remount the inside rim, then remount the outer tire and rim just like before. The now single rear tires will set wider than the steer axle, but so what? Am I mistaken?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2026 at 6:46pm
why would you remount the rims without tires on them ??  ... i would think you would want to move the rear tires INWARD a little bit ? ............ are you thinking the inner rim will protect the brake / caliper ?
Edited by steve(ill) - 07 Feb 2026 at 6:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2026 at 8:09pm
Are no special spacers, axle housings are different, dually Pickup Wide spread rear is Wider and has longer axle shafts. Put single wheels on it will remain wide.   To compensate for Inner dual tire from riding too close to springs.
The other concern is you now Offset the load to the wheel bearings. Dual Hubs the tires support equall mass against centerline of Hub, same is true for a single rear wheel axle hub.
Rear studs on my SD 250 are same length as for dually.
Edited by DMiller - 07 Feb 2026 at 8:11pm
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 52 minutes ago at 2:43pm
Seems if you go to rims for a single tire rear , the load would center on bearings and the clearances would be good , using the duel rims over to single would create offset which might become a issue .
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 29 minutes ago at 4:06pm
standard rims off a single tire axle would probably look good and be best... but now you got rims that are not interchangeble front and rear...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 16 minutes ago at 9:19pm
Thanks everyone, yes I imagine a guy could use ‘super singles’.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 15 minutes ago at 2:20am
My brother did this on a Dodge years ago. Take off all the offset wheels and the spacers from the front axle and put on single wheels all around, he used white spoke aftermarket wheels. He had a flatbed, so when done it looked no different than a 3/4 ton. This only works with a one ton pickup, if you have a one ton cab and chassis it has a narrow rear axle.
Ted
