Time to settle an argument…….. |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8342 |
Topic: Time to settle an argument……..Posted: Yesterday at 5:53pm |
Concerning the aspects of changing a dually pickup, to single rear wheel. Some have claimed there are spacers to remove, change brakes, etc. I say, if you want to keep the flaired fenders, just remove the tires from the inside dual, remount the inside rim, then remount the outer tire and rim just like before. The now single rear tires will set wider than the steer axle, but so what? Am I mistaken?
Joined: 11 Sep 2009 Location: illinois Points: 89986 |
Posted: Yesterday at 6:46pm |
why would you remount the rims without tires on them ?? ... i would think you would want to move the rear tires INWARD a little bit ? ............ are you thinking the inner rim will protect the brake / caliper ?
Edited by steve(ill) - Yesterday at 6:55pm |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35310 |
Posted: Yesterday at 8:09pm |
Are no special spacers, axle housings are different, dually Pickup Wide spread rear is Wider and has longer axle shafts. Put single wheels on it will remain wide. To compensate for Inner dual tire from riding too close to springs.
The other concern is you now Offset the load to the wheel bearings. Dual Hubs the tires support equall mass against centerline of Hub, same is true for a single rear wheel axle hub. Rear studs on my SD 250 are same length as for dually. Edited by DMiller - Yesterday at 8:11pm |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42194 |
Posted: 6 hours 36 minutes ago at 2:43pm |
Seems if you go to rims for a single tire rear , the load would center on bearings and the clearances would be good , using the duel rims over to single would create offset which might become a issue .
Posted: 5 hours 13 minutes ago at 4:06pm |
standard rims off a single tire axle would probably look good and be best... but now you got rims that are not interchangeble front and rear...
Lars(wi)
Posted: 3 seconds ago at 9:19pm |
Thanks everyone, yes I imagine a guy could use ‘super singles’.
