Time to settle an argument……..
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Time to settle an argument……..
    Posted: 3 hours 52 minutes ago at 5:53pm
Concerning the aspects of changing a dually pickup, to single rear wheel. Some have claimed there are spacers to remove, change brakes, etc. I say, if you want to keep the flaired fenders, just remove the tires from the inside dual, remount the inside rim, then remount the outer tire and rim just like before. The now single rear tires will set wider than the steer axle, but so what? Am I mistaken?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 59 minutes ago at 6:46pm
why would you remount the rims without tires on them ??  ... i would think you would want to move the rear tires INWARD a little bit ? ............ are you thinking the inner rim will protect the brake / caliper ?
Edited by steve(ill) - 2 hours 50 minutes ago at 6:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 36 minutes ago at 8:09pm
Are no special spacers, axle housings are different, dually Pickup Wide spread rear is Wider and has longer axle shafts. Put single wheels on it will remain wide.   To compensate for Inner dual tire from riding too close to springs.
The other concern is you now Offset the load to the wheel bearings. Dual Hubs the tires support equall mass against centerline of Hub, same is true for a single rear wheel axle hub.
Rear studs on my SD 250 are same length as for dually.
Edited by DMiller - 1 hour 34 minutes ago at 8:11pm
