Time to lite them up !!!!
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Topic: Time to lite them up !!!!
    Posted: 16 Oct 2020 at 7:01pm
  Just lit it up this evening , heats ,Business Shop , showroom  and my house . All 24/7
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2020 at 7:09pm
Great looking setup,, luv those outdoor wood burners
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2020 at 7:32pm
Yup, lit mine two days ago, glad I did. snowed here this morning... but was gone 1/2 hour after it quit.... but you know it ain't gitten any better till spring rolls back around again...
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2020 at 7:49pm
Gosh, I just may have to give some thought to turning off the a/c here? Nah, I will just lay down till that thought goes away.
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2020 at 7:58pm
Starting my Hardy Heater tomorrow. Going to be cold here for awhile!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2020 at 8:24pm
Is that a whole season's worth of firewood Fred?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2020 at 8:48pm
17 cord's in there now , last year I used 14 to heat all winter .was a mild winter .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2020 at 8:49am
STILL wishing I had set one up here, but kept running out of time and cash to get it set up, at least with ground source the expense is lower than conventional heat sources.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2020 at 8:42pm
Fire wood equals work. Ruined many Sat**days. Not for me.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2020 at 8:54pm
Might get mine going tomorrow. Ugh....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 7:51am
 With logs hauled here n then using the correct splitter ,takes !/2 the work out of it .
 Nephew bought one of these splitters that I  trade out my dump trailer for using splitter     Was his idea so I agreed .
    Split everything right aside wood shed .NO picking off the ground after split .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 9:54am
What exactly is that Fred? So there’s like a table after the wedge for the split wood, but what’s the black doohickey?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 10:49am
Hyd. adjustable wedge Makes it a 4 way split .or he has a 6 and 8 way wedge .Or just remove wedge  for single split .
Edited by Fred in Pa - 18 Oct 2020 at 10:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 12:07pm
Well, that’s cool, but not that black thing! The expanded metal cage type thing. And what brand?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 3:43pm
Any of your neighbors complain about the stench of the smoke when it's damper door has it in "smolder mode" ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 5:30pm
Freeguy ,NO !!!  been 11 years burning it . Doing the day I only feed it what it needs as my business is right here .I only burn seasoned hard wood n you can see it says DRY. Its like any thing else once u learn the system it works .The guy above me that lights a shop stove in the evening and the dum@$$ burns green and wet wood has a issue with the guy on the south side of him .
    Also having the stack at right height helps
Edited by Fred in Pa - 18 Oct 2020 at 5:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 6:34am
Tbone 95   ,That is lift for big wood its just not down on ground in picture .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 9:04am
Kinda thought so. So, what brand is it, or did you modify it by adding the catch table on to it?
Still using the Manuel Armstrong splitter here. Ain't as much fun as it once was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 6:01pm
Thanks for the reply, apparently 98% of the guys burning these "here" are burning green wood Confused. And it stinks worse than chicken s^*t Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 6:34pm
When was cutting firewood, first year cuts were stored on other farm for a full winter and summer, seasoned.  Then brought out and used or sold.  The current conditions I have is seven larger walnut trees we had taken down as 1, TOO close to power lines then 2, had gotten to a size would become useless in a few years for logging and 3, were a few on drainage creek bank root mass washing out.  One was already beginning to hollow out at stump and had to be trimmed to solid to sell.
Have maybe 5-6 Cords of Limb wood I need to hack down to firewood size and store up to dry out then can sell next season.
