tiller
ocharry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Topic: tiller
    Posted: 04 Nov 2018 at 9:40am
any of you guys ever use a tiller on the back of the tractor???
been thinking on maybe getting one to do some deer plots
anything i need to know before i start looking,,,good brand,,how well they work,,,things to look for as far as how well it would work???
been thinking on a 6' tiller to hang on the back of my 170,,,,only be using it to make deer food plots
ocharry
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 10:10am
I've got a 5' one on the back of my D-14. It works GREAT !! Got rid of the Ford LGT125 with 3' tiller this summer too !
It'd be nice if the D-14 had an ultra low 1st gear though, I have to 'feather' the PD for the first couple of passes. Now that most of the garden has more 'tilthe' ( compost + pony poop), 3rd pass it goes down and I can stay in 1st low.
I should adjust the tiller to lineup with the right rear wheel ..one day...maybe.....
The tiller was made in Italy, zero wear on the blades, maybe 5 years old now. Whatever you buy...always grease it before use, be sure it's adjusted correctly, have plenty of shear pins onboard ! Big rocks will bust the pins.
Jay
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 11:09am
Seen a lot of them working but finding a tractor with a low enough speed is one problem - should almost be a creeper gear - especially when breaking new ground .
 In many ways would be best to use a regular plow to break sod and then till after
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 12:45pm
Have used a 6ft Befco for years behind a Kubota l4310. I believe it's around 36 or 38 PTO hp and it handles the tiller fine
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 5:50pm
I have a Kubota L2202 grey market, that is phenomenal, on the tiller.  It gots a 16 speeds, an aux transmission, on the fender, it were a rice paddy tiller.  Others are right, sometimes you just need to go real slow.  Since I got the new (to me!) b2100, hydro Kubota, I have not used it for tilling, cause the new one is much easier to get on and off.
I have a 5' cheap tiller I sometimes use, on the D-10.  Always has worked best, after plowing and discing...Wink
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 6:23pm
6' King-Kutter here. Had it 15 years and used heavily , still going.--- Be aware that NOT all tractors have a slow enough low gear to make them usable.  Had to use mine some on a WD, ---NOT a good deal,-- 1'st gear WAY too fast. ---NO such thing as too slow for tiller! LOL!!! thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2018 at 9:13pm
I have a 40" wide tiller for my wheel horse and it does a great job in the garden...the wheel horse has a 2 range trans in it and in low low it just creeps and give the tiller time to work
That why I was asking about one on a big tractor....the 40" tiller in a bigger....maybe 2 acres...would take forever
But a 6' tiller on a bigger tractor would be nice....just dont know if my 170 would or will go slow enough in 1rst gear
The ground has been worked before but it has been a few years
Ocharry
macec3(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macec3(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 5:51am
I have a KingKutter from Atwoods. Works really well. One pass and plant.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 6:31am
I just checked TractorData and your 170 goes 2 MPH compared to my D14 doing 2.3. That's about 15% slower, so already it's better ! Also I don't run the engine fast, maybe 1000 RPM( fast idle...), let the tiller dig in and chew up the soil. This is in the wife's 1/3 acre veggie patch which I've added a lot of 'good stuff'.
Plow 1st, both N-S, then E-W, let stand 2-3 days THEN rototill. I like to till E-W then W-E,seems to 'fluff up' the soil very well. This yer I bought a subsoiler and did the whole garden, seems to have helped, so I'll do it again next spring.
