Throttle issue
Kdelucca View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kdelucca Quote  Post ReplyReply Direct Link To This Post Topic: Throttle issue
    Posted: 29 Mar 2024 at 6:25pm
just pick up allis Chalmers D17 series 11 gas tractor don’t  know much about it having issues with the throttle, at idle it runs full throttle at full throttle it idle . Is there an easy fix or do I need to open Governor control?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 6:39pm
did someone put an aftermarket carburetor with the lever pointed in the wrong direction ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kdelucca Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 6:45pm
I believe it’s the correct carb . I did check it’s tsx853
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 9:46pm
I'm having a difficult time wrapping my head around this one. When the hand throttle is pulled down to a horizontal position (3 o'clock), it should have pulled rearward on the linkage that runs down the right side of the engine. This action stretches the governor spring inside the timing cover causing the governor to make the engine go to 2,000 RPM high idle. Going up to the 1 o'clock position with the hand throttle idles the engine down to slow speed as the linkage has moved forward alongside the right side of the engine. How or why anyone could reverse this linkage action is beyond me. Pictures of the carburetor and the left side of the engine might be helpful.
Edited by DrAllis - 30 Mar 2024 at 7:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kdelucca Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2024 at 6:58am
when the hand throttle is moved to the 3 o’clock position the linkage moved to the rear of the tractor I will send pic later thanks
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2024 at 7:02am
3 o'clock is full throttle. 12 o'clock is idle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kdelucca Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2024 at 5:58pm
ok thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 4:45pm
Still waiting for a reply.
