Three point sway control
bwp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwp Quote  Post ReplyReply Direct Link To This Post Topic: Three point sway control
    Posted: 25 Apr 2011 at 10:31pm
Hey guys,
I put a 190 three point on my D19 and would like to know what was originally used to control sway. It looks like it may have used blocks as sway control? I think I'm just going to fab up some telescopic sway control arms.
Thanks,
Brad
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 10:34pm
They used "sway blocks". They could be removed or added depending on the catagory of 3pt you needed.
bwp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwp Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 10:55pm
Thanks Dan
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 11:11pm
They should look like this.  The bottom ones are for cat II, the small ones stored above are for Cat I implements.
ALLIS EXPRESS!
This year:
bwp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwp Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 11:59pm
Ok so for curiousity, does anybody have a set of cat 1 and cat 2 sway blocks off a 190 they would be willing to part with? Thanks.
Brad
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 5:49am
I am still on the scrounge for a set of Cat 1 blocks.  Cat 2 blocks are still dealer and aftermarket available but the bolts are not.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 9:27am
I'd like to find some of the cat I ones also, so if anyone has any extra, let me know.  Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 11:21am
Good luck finding sets of the Category 1 sway blocks...very very hard to find.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 12:19pm
Here is a better pic of the Cat I blocks. Mine are under lock and key!
ALLIS EXPRESS!
This year:
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 12:31pm
I have a pair, not for sale.  As Mike mentioned, they are RARE.  I think they were optional.
bwp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwp Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 4:36pm
Ok...I guess if someone on here does have an extra pair they want to sell, I will be the guy that started an all out bidding war. I called probably the only all AC salvage yard here in CA, and was told they have a couple of 190s out in back, but the mechanic was too busy to walk out in the yard and look. I was also told I couldn't come and look for myself. Kind of irritating since it's not too far a drive. I kind of thought these sway blocks would be hard to get ahold of. If so, I'll just make some pretty solid adjustable sway arms. Thanks for all the responses.
Brad
rhartwick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rhartwick Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 6:22pm
Hey Eldon,
Any chance you could post the thickness of the Cat 1 blocks?  It seems like a regular hunk of steel cut to roughly the dimensions should work.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 7:01pm
I had set lazer cut from steel chunks by my welding guy. My T+D friend still has them for drilling, been awhile, I better call him.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 7:13pm
Doesn't look like it would be a difficult casting, though it would be handy to cast the square bolt head recess. Carve a pair out of wood at little bigger with some shrink built in and find a cast iron foundry.
Gerald J.
