Three point hitch 4 disc plow
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Three point hitch 4 disc plow
    Posted: 10 Sep 2023 at 1:53pm
Looking at one . Gotta wonder if my D 15 will pull it ok ? Going by the pics the discs look about 20" . Any thoughts ? Thanks !
Edited by ACinSC - 10 Sep 2023 at 4:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 4:41pm
It might, depending on your soil.  I know they pull 3 bottoms OK in most soil. Limiting factor may be weight, can you keep the front wheels on the ground?Wink
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 4:46pm
I would measure those discs again. They should be 26 inches in diameter. And if you are plowing light soil it should be ok but my wd 45 struggles with three in heavy soil
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 4:53pm
Thanks guys, I'm just going by a couple pics. May go look at it as it's about an hour away. Does look very heavy.Our soil is mostly sand.Thanks again
Edited by ACinSC - 10 Sep 2023 at 4:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 4:57pm
One thing I don't understand is where the top link should hook up there's several vertical bolt holes? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 5:41pm
All implements should have more than one top link hole!! but they usually don't. As much as SAE and ASAE engineers tell you 3-point hitches are all the same dimensions, they are NOT !! Extra holes should allow for you to adjust so you can get enough transport lift and still achieve the proper working depth without compromise on either.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 7:13pm
The snap couple ones have two sets of holes, one position is for transport, the other for field work
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 7:17pm
As always, Dr Allis is right. To my eyes these holes look too small for a Cat 1 top link pin . Thanks guys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2023 at 12:31pm
Also looking online at a Dearborn plow with two 24" discs . Pretty sure my old D 15 can pull that . Thanks
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2023 at 2:02pm
There were (and are still) a few styles of disc plows made. Are you referring to the Dearborn/'One-Way' style, that looks like a super-sized gang off a regular disc. Or is this one with individual discs on separate axles (more like a moldboard plow)?
In my (albeit limited) experience the HP/cutting width ratio on a disc plow is about the same as a moldboard plow. I have a Dearborn that cuts 42" (I think 5 disc?). Never pulled it on an Allis, but have put it on my Case 530 & 630 (40 HP and 48 HP respectively).
Both pulled it fine in sandy loam. Only time I wanted more HP was actually in really, really sandy soil where I was trying to go deep. It would drop itself in as deep as I wanted it, but really sucked some HP once it got up near the axle/shaft. Which of course is what you'd expect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2023 at 2:15pm
Thanks Daniel , both of these are the 'one way' kind .
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2023 at 4:00pm
I think the ones that look like a gang of a disk are sometimes called disk tillers and are more common in dry land regions. The ones that resemble the moldboard plow with a big disk and a scraper shaped like a small moldboard (but bigger than a joiner) is called a disk plow . they are great for busting up "virgin" soil and are more common in the south.
Just to confuse things a little more, I think I saw a picture of something that looked like a bastard child of the two in Wendel's book.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2023 at 6:14pm
Thanks , Dr P . I'm in the south and just found another one . I think it would do a good job on our firebreaks/roads at the 'farm' .
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2023 at 8:58am
I would think a 4-disc plow would be one **** of a load for a D-15, just to pick it up. There is a video from Hutch this year, J&L video, our own Luke R is pulling a 4-disc plow, with a 180!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2023 at 11:06am
Thanks Mike , you're probably right . Sure looks heavy in the picture .
Edited by ACinSC - 12 Sep 2023 at 11:07am
This page was generated in 0.246 seconds.
