this guy is nuts
D19allisowner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19allisowner Quote  Post ReplyReply Direct Link To This Post Topic: this guy is nuts
    Posted: 28 Dec 2021 at 6:03pm
If you choose not to decide you still have made a choice.
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2021 at 7:14pm
Yep,your right he's nuts! Here is what happened when his .50 cal rifle blew up!https://youtu.be/1449kJKxlMQ
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2021 at 7:27pm
Originally posted by D19allisowner D19allisowner wrote:
This Isn’t Your Grandpa’s 30-06 👴 ( The H.C.A.R. ) - YouTube
 I want one of these!
Me too!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2021 at 8:55pm
My Dad carried a BAR in WW2.Said it was too heavy. The HBAR is a lot lighter than the original. I believe an AR 10 would be better.
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 11:18am
Me too.     AR-10 ?? I have a much higher opinion of the 06 round vs the .762 but that is just me.Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19allisowner Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 12:48pm
I saw that one a long time ago. He's lucky to be alive.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 12:53pm
I gotta say......he's a mentally tough dude to get back on that horse.  I'm thinkin' that might have scared me off permanently, sound reasoning of freak accident or not.  Wow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2021 at 5:21pm
SLAP Rounds are for OPEN CHAMBER Weapons(Browning Ma Deuce) ONLY and without Muzzle Brakes for a Reason.  SABOT LIGHT ARMOR PIERCING. Key Word Sabot.  It splits and separates from the Slug at END of Barrel IE the Muzzle.  Muzzle Brakes are Slotted and at the Muzzle where that piece of material lodges and all hell breaks if not breaks loose.  Was NOT a Super Hot Round as nearly ALL .50 bmg rounds are Compressed Powder Loads, to make one scary use the WRONG Powder or in His case put a Sabot thru a Muzzle Brake.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 6:55am
Whatever the reason, I stick to my point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 7:35pm
This guy is nuts!https://youtu.be/o31r6nV5gck
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 9:02pm
A TRUE Mindless Imbecile!!
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 11:33pm
In August of 1965 I was with Hco 2nd btn 4th Marines 3rd Marine Div. on Operation Starlight in Vietnam, we carried M-14's and one member of each squad had a selector that would turn that rifle into a fully automatic weapon, capable of firing 750 rounds per min. at that rate the rifle was almost uncontrol able, M-14 fired a 7.62 round similar to todays 30.06. I didn't see any reason to fire the M-14 fully automatic in a combat scene, and I still don't. If you can fire as fast as you can pull the trigger you have better control of that weapon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 4:52am
Dave, I agree, shooting rounds that you don't know anything about, or a saboted round through a muzzle brake is asking for a malfunction!
I hope he learns, but sometimes life's learning curve is mortally steep!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 6:14am
Darrel, I Had qualified M16 then M14 at Knox when was in, select fire had been converted to the same Style as M16 to Burst Fire four rounds. Much sweeter machine at that time.
