Think cheap/aluminum round bar
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Think cheap/aluminum round bar
    Posted: 20 Dec 2018 at 6:14am
I’m looking for 3.5” or larger aluminum round bar. I only need 6” long. I’ve tried those online metal places and and and I’m not giving $75.00 for this.
I’m making a 3.5” by 6” long flat drive pulley.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 8:00am
Check with some machine/fabrication shops and see if they have a piece of scrap they would sell. Might even be able to trade one of the employees a 12 pack for what you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 8:09am
Why aluminum? Is a little soft even for flat belt. Steel pipe welded to a central spindle would be stouter.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 8:23am
I wouldn't call 3.5" x 6" "scrap".  That's a pretty valuable piece.  Not to say you couldn't find it relatively cheap at a shop.  Most aluminum should work fine for a pulley.  12" spoke design aluminum dual V runs the unload on my corn bin.  But if you have to buy it, steel would be much cheaper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 8:33am
The plan calls for aluminum but I’ve given the pipe on a hub lots of thought.
It goes on the shaft of an electric motor and turns a rubber tires drive wheel.
The 3.5” is somewhat important for proper RPM.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 8:39am
   Hey Thad,,,check out McMaster-Carr. I bet they gots a pully the size you need.  Fact is,,I may have one in my "warehouse" . I'll look soons I get up,,,,,,,,Wink
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 9:32am
Drink lots of beer and get the smelter going.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 10:54am
X2
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 11:23am
Any good scrap yards in your area?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 11:43am
One that doesn’t sell to the public and one ran by a guy named Nick the prick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 11:57am
OK I can't 'see' how a 6" long metal pulley will attach to a std electric motor. Most only have at most 2" of shaft. Having 4" of spinning metal at 1725 RPM is, well, a recipe for 'oopsy !!' Something about mass, inertia, and them physics things we never really studied too hard...
Have to ask what's the HP of the motor ? I'm thinkin ghtis is for the forgling hammer gizmo ??
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 12:00pm
Layne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Layne Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 1:25pm
When people would come in my machine shop and ask to look through the "scraps", I would show them a trash can full of shavings. Anything bigger than that I can make something out of and it's not a scrap. A piece of 3.5" round bar would have been a top-shelf item for sure. But it depends on the shop. My brother makes offshore oil rigs. They throw out more scrap in a day that my shop would have used in 10 years. But they only use steel, no aluminum.
Edited by Layne - 20 Dec 2018 at 1:30pm
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 1:41pm
If you are in Wichita  go to "The Yard"     725 E Central Ave    |    Wichita, KS    |    316-265-4672    |    1-877-265-4672    |    Hours: Mon-Fri, 8:30-5:00 (Outside/Metals 4:45)   Saturday 8:30-4:30
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 6:35pm
Jay
Yes it’s for the power hammer. It’s a 1 hp 1725 rpm motor. If it’s made proper I don’t see why it wouldn’t stay put. Key way and set screw hold it in place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 6:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 8:51pm
 Chit Thad,,,,,I was AFU wasn't I,,?? LOL Don't know why I thought you was lookin for a 3 1/2 X 1" wide,,,,,chit,,,guess I been hangin around ole Shameless too dang long,,,,,,,LOL
allis g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis g Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 9:17pm
at those RPM's you'll have to get it balanced on a dynamic balancing machine or it will destroy itself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2018 at 6:01am
Well the one thing we have in little ole Busch Arkansas is an engine balancing machine shop and as luck would have it he’s one of my closest friends. Maybe I’ll just have him machine it as well and I’ll be working n something different at that time.
The engineers that designed this never made mention of balancing it. I wonder if all those I’ve seen in the hundreds of videos were balanced???
Other parts are definitely required to be sent to the balance shop. I appreciate the concern.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2018 at 6:22am
Thanks for the 'update'. Kinda thought I was thinking right.
I was 'forged in fire' so I've sorta seen what you're building
OK the  'problem' is that you've got a heavy mass, spinning 1725, that gets 'loaded and unloaded' often,that'll put a LOT of stress on the front bearing of the motor. Not to mention the shock waves when you actually whack the steel !!
From a mechanical view, I'd carve out a 'recess' to install a '6205' bearing in the outside end  and add a support to the motor mount.A stub shaft,supported in a pillow block would work. You've got lots of room, so think heavy duty.
BTW every water pump I've tore apart, it's been the FRONT bearing that was 'noisey' and wore out. well supported rear was fine.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2018 at 6:37am
The heavy mas isn’t spinning 1725 rpm only the motor and this aluminum flat drive pulley. Picture it as a clutch. You step on a pedal which raises the motor til it touches a 30” is rubber tire. 3” against 30” is serious reduction and then one must figuare the built in slippage which means the tire will most often never meet full rpm. It’s designed to slip and run the hammer at less than 200 blows per minute.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2018 at 6:54am
The 6" aluminum 'pulley' is the spinning mass I was referring to. It's 'far' away from the front bearing of the motor. Depending of where the tire contacts the pulley , pressure will be 4-6" from the bearing. Pulley will weigh 5# ??
I'm thinking guys don't think about the problem as motors are free or dirt cheap and easy to replace the bearing when needed ?
Can I assume there will be a keyway ?
Just thinkin g of things to do ONCE and not have to rebuild 'bigblu' every few dayze....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2018 at 7:09am
Yes it will have a key way which I’m not able to machine. I do realize what you’re talking about on bearing pressure. Picture this. The flat pulley 6” long and 3” diameter is drilled 2 inches deep it slides on the motor shaft that fill 2” it rubs the tire in the middle of that 6” pulley which puts the pressure 1” beyond the end of the shaft. Keep in mind this isn’t serious pressure. It just rubs hard enough to get that tire rolling and designed to slip to control speed.
Now picture a drillpress motor with a step pulley. It sticks farther beyond the end of that shaft than that flat pulley rubs on that tire and the drillpress will have constant belt pressure on the bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2018 at 7:25am
You'll be fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2018 at 8:04am
good , I can 'see' it better now ! Just want you to build it right the first time...I seem to have 2 or 3 'prototypes' here.....sigh.
never thought about drill press motor !, though it's vertical they seem to last forever....
Jay
