The Plastic/Foil Oil Jug Seal ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: The Plastic/Foil Oil Jug Seal ??
    Posted: 10 Jun 2020 at 6:20pm
Sadly, I topped-off the 5.4 last night with a pre-opened jug that had a "hang tag" remnant left on the lip that sure-as- SH*T fell off and into the fill port Confused. It was maybe a half sq. inch in total area but long and slender. Please tell me that this will get caught in the filter or at the very least, dissolve Big smileBig smile. This is the first time in 37 years that this has happened to any engine that I've changed oil in Embarrassed. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 6:22pm
If it makes it to the oil pan, will probably get stuck on the suction screen INTO the pump... Stay there forever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2020 at 7:22pm
It will catch in the first place that has a smaller passage then it is. Years ago my Aunt cooked the motor in her car when her Auto Mechanic son topped of her overflow tank and let a piece of the foil fall in. It would let Anti-Freeze into the overflow tank when the car warmed up and then would plug the outlet when the car cooled off, thereby not refilling the radiator. That little piece of foil will still be intact when the next Ice Age comes.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 5:43pm
I had a guy bring me his wife's car, he did the same thing. We pulled the pan, Plastic was sucked up to the oil pump screen. Probably would never have hurt anything. He didn't want his wife to know he dropped it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 6:05pm
Working HD Trucks saw LOADS of those on pickup screens in oil pans and the tin seals for Fuel additive in tanks or stuck in fuel lines/filter heads. Know several guys use it as a extra spill control valve to load the bottle neck into a fill tube then squeeze the jug to get flow, One wiped a engine with doing that.
Edited by DMiller - 11 Jun 2020 at 6:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2020 at 6:25pm
One of my D-14s started running rough... needed choke and it's 100 in the shade...
..dang no gas to carb.... after 2 hours of yank tank, clean it, sediment bowl looked OK, blow out gas line...still lousy... took sediment bowl off again... thought I saw something, na....
Ok, I did see something...
it was  a sliver of yellow in the inlet port....
WTH ????
all I can think is that it was a piece of plastic gas can nozzle that got shaved off poking spout into the tank filler hole. When ?? I don't know... but that is what stopped a D-14 !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2020 at 3:18pm
OUCH jay......
Seein as it was that small Jeff, it'll prolly never be a problem.
