The One-Ninety XT Story for new members |
Page <12 |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21857 |
2 3/4" for the small (same as D19) and 3 1/4" for large (same as 200-7000-D21)
Don(MI) ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: Michigan Points: 3887 |
Thanks for the education, this has been an interesting thread to read so far.
Galatians 5:22-24
"I got a pig at home in a pen and corn to feed him on, All I need is a pretty little girl to feed him when I'm gone!" |
michaelwis ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Wi Points: 8765 |
Cut my teeth with a 65 190XT ... very few problems .. traded it for a 986 .. wish i had it back .. It was traded in in 1980 at Howery Imp .in Darlington Wi. maybe a forum person now owns it ?
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60 GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4540 |
I just bought a straight one ninety with the 265 gas engine and the small axles. It hadn't run for a few years and had a push rod out of position. It runs good now except
that I can hear valves hanging up and poping at an idle. Is there an oil additive that can cure this or do I need new valve springs?
Bob D. (La) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Louisiana Points: 25529 |
Add a quart of Rislone and run it/work it. Should clean things up.
tractorman ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: west central wi Points: 1046 |
okay what is that measurement ?
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
sorry wrong placen for my question. Tman
ANy body find those diameters mine is 3.25 inches, and hoping it is the bigger one.
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Rislone might work. Another way is to change the oil to a high detergent oil. Most diesel oils have more detergent in them, and synthetic oils have even more. If it were my engine, I would put Mobil 1 5w-40 turbo diesel oil in it. That oil is also rated for spark engine use. And then put a load on it for a while. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
KGood ![]() Orange Level ![]() ![]() Joined: 17 Nov 2009 Location: Logansport,IN Points: 955 |
The one I bought is a 65gas XT with a 301 that is dated 64. It has the 2 and 3/4 axles. Something that is neat is the lever behind the tractor under the tank that you put a jack handle in to raise and lower the 3PT. I heard the newer ones didn't have it. Someone thought it was probably unsafe. There is a bungee cord tied to the sea After I got the slop out of shifter linkage it feels tight and I can't get it to pop out of 1 through 3 but 4 you can push the shifter quite a bit further from were the detent is. Isn't there a fix for this like redrilling detent hole?
Page <12 |
