This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | ||||
The Forum | Parts and Services | Unofficial Allis Store | Tractor Shows | Serial Numbers |
The Little AC's, a history lesson |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22772 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Oct 2018 at 4:43pm |
Ken in Texas ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Henderson, TX Points: 5903 |
Ken in Texas thanks CTucker for posting the correct address to "The Little A-Cs". Bill Long can't help but like this AC History Lesson as much as I did
GreenMule ![]() Bronze Level ![]() ![]() Joined: 09 Dec 2017 Location: NC Points: 26 |
More good stuff to keep,thanks for sharing
TramwayGuy ![]() Orange Level Access ![]() Joined: 19 Jan 2010 Location: Northern NY Points: 9311 |
Great reference! However, I notice that the section on hydraulics uses the term ‘power booster’ for the weight transfer system. The correct term is ‘Traction Booster’.
Oliver Corporation used the term ‘Power Booster’ for their optional shift-on-the-go clutch on the 770 and 880 tractors. Edited by TramwayGuy - 23 Oct 2018 at 6:02am |
Hunt4Allis ![]() Orange Level ![]() Joined: 13 Mar 2018 Location: Ohio Points: 1036 |
Wow, great info
Thanks guys! |
Gafry53 ![]() Bronze Level ![]() Joined: 27 Oct 2020 Location: Ephrata,Pa. Points: 16 |
Just bought a Allis Chalmers B model that need governor work . The tractor bogs down when going up a hill?? Also bought a Model C that gasoline tank leaks and is a narrow front that need replace wheel slop is bad. Any help on gasoline tank leak or the Engine bogging down?? Going to due a tune up kit on B to see if that helps bogging ??
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 65819 |
Welcome Glen... you posted in the Farm Equip KNOWLEDGE BASE, where we store TOPICS that come up over and over... The Post Area above Knowledge Base is FARM EQUIPMENT .... You will get a LOT more answers in that area.
Some with a small gas leak have removed the tank, cleaned and put JB WELD over the area.. Others have used a couple layers of fiberglass to patch.. Engine bogging down could be governor if it is not working.. Could also be timing or loss or gas in carb... Go to the FARM EQUIP area and start a post. Others will explain how to set the governor and test.
