the centrifugal advance in the distributor
alan1959 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan1959 Quote  Post ReplyReply Direct Link To This Post Topic: the centrifugal advance in the distributor
    Posted: 27 Aug 2016 at 10:43pm
Where is the centrifugal advance in the distributor on a series III D17?
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2016 at 11:43pm
Under the point/condenser mounting plate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 6:30am
A Don mentioned, they are located under the breaker plate. If you happen to notice the weights are stuck from rust or oil, you can remove the weights, (make sure you don't loose a spring) clean em' up with some brakekleen, or if they're rusty run em' on a wire wheel, then give em' a couple coats of dry graphite lube. This will allow them to work nice n' free again. DO NOT us oil on em' or grease! HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan1959 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 7:19pm
Thank you all so much for the help. Will check out and see. Tips are greatly appreciated. Will post when I am done.
This page was generated in 0.140 seconds.
