The best spark plugs for the B
2011dandd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Topic: The best spark plugs for the B
    Posted: 08 Mar 2019 at 5:58am
Again I’m leaning on those with far more experience and expertise,
What are the best spark plugs to get for my hand crank 1947 petrol/tvo(heavy oil) b
Will probably only be running on straight petrol from now on
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 6:17am
I put NGK B4 in both of my B's. One is crank star the other electric start. I have been happy with them.
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 6:27am
NGK XR4IX Iridium IX
Above is the best plug I found for my Allis-Chalmers. They start and run perfectly every time. They are a little pricey but they will be the last plugs you ever put in your tractor. The best price I've found is at Rock Auto.com. Autolite, Champion, and AC conventional tiped plugs are junk. I tried them all. I don't run conventional plugs in anything I own any more. Click on below.
X
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 10:38am
Cheers
Thanks for the advice
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 10:43am
Phil 48
Is this the exact code number of the exact plugs I need?
Same gap setting?
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 11:53am
Autolite 295 stay away from champions
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 12:03pm
2011dandd
Those are the right plugs for your B, just set gap at .035".
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2011dandd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 1:00pm
Read a lot about those plugs. They sound great
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2019 at 11:12pm
I've been running A7C Motorcraft plugs in my CA. The best thing you can do to reduce plug fouling is install a 195 degree F thermostat. A hot engine burns fuel cleaner and more completely. The next best thing is if you have distributor type ignition, update it to electronic. Running the engine hot and running .045 inch plug gaps has eliminated all of my plug fouling problems.
