The best mower deck spindle? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10933 |
Topic: The best mower deck spindle?Posted: 27 Feb 2015 at 2:28pm |
Who has the best mower deck spindle? In ease of maintenance ,replacement and longevity for the cost? Thanks Tracy
Butch(OH)
Posted: 27 Feb 2015 at 3:45pm |
I like the spindles on our Scag and Bunton mowers. The spindles are hollow and use a long 5/8 bolt and nut to retain the blades instead of cap screws and common flat washers can be used if you lose the spacers some how. Bearings are common off the shelf too but in 10 years we have not had to change any.
Tracy Martin TN
Posted: 27 Feb 2015 at 5:23pm |
Butch, the spindle assy for the 616-620 are about 400.00 each, less pulleys and bearings. I think I am going to make a new style like the Dixie Chopper uses.They look heavy and should last like the ones you mentioned. Thanks tracy
Toscani NE SD
Joined: 21 Jan 2011 Location: Milbank S.D. Points: 369 |
Posted: 28 Feb 2015 at 8:27am |
in my opinion u should never need a new spindle,my 620 which I bought used still has all original spindles everything is original no new bearings,if you grease them often u wont have any trouble,mine has mowed a lot of acres,i also have several large john deeres with 60" decks,never replaced a bearing yet,over 1300 hrs
Tracy Martin TN
Posted: 28 Feb 2015 at 3:53pm |
That would be great, but mine had been abused before I got it. You sure don't want to buy any new ones, at the price they are now.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4070 |
Posted: 28 Feb 2015 at 4:45pm |
thats areal good question used ones i would probley rebiuld cast iron john deere huosings new ones just looking in the oregon catalog at new ones probley would order some for bobcat or exmark we sell a ton of the newer mtd and ayp spindles they are cheap but not very toughf
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25246 |
Posted: 28 Feb 2015 at 5:27pm |
One trick I picked up is to add a grease zerk( if not already there) and pop the 'dust shields' of the bearings to expose the race to the grease. Neighbour has 25 years service doing that. He also removes the spindle assemblies every fall, greases the nuts/bolts holding them onto the deck. 'Old school' stuff....
sure wish I could get $400 for a spindle !! heck I'd settle for $200.... Jay |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 28 Feb 2015 at 5:50pm |
Swisher mower I have the deck bearings went out , found they used sealed bearings but not shielded = so I replaced with sealed and shielded bearings - was thinking of adding grease zerk to space and pulling the inside seals but figured 4 years service on first set - so should last about the same or longer this time around .
