The Aluminum Truck Bed ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: The Aluminum Truck Bed ??
    Posted: 26 Feb 2021 at 8:18pm
What ever happened to them ?? Several years ago every-other truck commercial (FORD) touted the aluminum bed and possibly frame?? There hasn't been any ads for them in several years ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2021 at 10:10pm
it's simple...they was made outta 1/2 steel and 1/2 alum, when the steel rusts out, the alum just falls out! then it's flatbed time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2021 at 10:28pm
The FRAMES are still steel.... Chevy tried to make a big deal out of FORD aluminum beds for a couple years.... FORD still doing good , so Chevy stopped the adds... better things to talk about.
Aluminum-bodied Ford trucks
Since 2015, the Ford F-150 has had an aluminum body. ... At the moment, the Ford F-150 and F-Series Super Duty are the only trucks that have both aluminum bodies and aluminum beds. For 2019, the Chevrolet Silverado did replace some steel body panels with aluminum ones, but not the bed.
Nov 23, 2019
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2021 at 10:30pm
The BIG thing for FORD was the LOSS of 700 POUNDS of weight... better gas mileage.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2021 at 6:56am
Despite GM's ads telling how bad aluminum is, all of GM truck body moving parts (doors, hood and tailgates) are now made of aluminum.
Fiat uses a "selective mix" of aluminum and composites in the Ram pickups.
Edited by WF owner - 27 Feb 2021 at 6:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2021 at 5:56pm
Thanks for the replies, but there are NO more ads on tv touting the aluminum beds of any manufacturer Ouch ?? Why ??
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2021 at 6:13pm
Because it's old news and nobody cares.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2021 at 6:19pm
Was thinking the same thing
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2021 at 6:46pm
Do not hear much of the Super Stiff Dodge Truck frames either.  BAD Juju, if does not flex will break, standing engineering principle.
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2021 at 6:47pm
Why would they?? Its old news... Nobody spends advertising dollars on stuff that's been out for years now. Like has already been said, Ford has had aluminum beds now for 5-6 years.
Making a living farming with and working on Allis Equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2021 at 6:51pm
Bunch of neighbor cattlemen have aluminum flat beds, can get more gear On the truck and not be overloaded by flatbed weight.  HOWEVER, are a PITA to find a decent welder to patch cracks or make mods to, as well still corrode and corrupt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2021 at 8:06pm
Welding oxidized or dirty aluminium requires a whole different skill set vs new metal IMO.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2021 at 8:13pm
When the old cows get to ramming around and push one another into the aluminum side, they cave it in. Last I talked to the body shop man you had to replace the whole box, can't buy the sides. He was buying steel boxes to replace the crumpled up aluminum boxes or replacing them with flat beds.
Edited by HD6GTOM - 27 Feb 2021 at 8:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2021 at 10:44pm
WE have two chevy commericals on the TV here..... One talks about the tail gate step... the other is an "off road truck", that has Ranchero shocks and 2 inch spring lift.... thats the  "NEW IMPORTANT THINGS". Wink
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2021 at 1:34am
Yet you will never give a source for these "steel boxes."  They must be piled beside your 16ft tall trailer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2021 at 5:21am
Ford has had the FX4 off road package with Rancho shocks and a tailgate step for years .
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2021 at 6:20pm
So, am I to "assume" that ALL truck beds are aluminum now ?? No steel offered at all ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2021 at 6:23pm
NO.... Ford is the only one with an aluminum BED as far as i know... everyone else uses aluminum in the fenders  / doors / hood / and trunk lid of cars to save weight.. Some use a lot of aluminum, some only do hood and trunk lids.
Like mentioned, it is so common any more... nobody says much about it.
Edited by steve(ill) - 01 Mar 2021 at 6:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2021 at 6:34pm
Thanks for the clarification Steve.
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2021 at 9:21pm
Years ago a friend had an Oldsmobile with an aluminum hood.  Went to a funeral and the director put a flag with a magnet on the hood to indicate the end of the procession, every time he stopped it would slide around, finally stopped and put it on the top or somewhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2021 at 4:48am
GM and Dodge truck NON Dually beds are steel, have gone to some plastic/composite fenders on Dodge and plastic extensions GM but only Ford has all aluminum beds and cabs.  All you need do is search.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2021 at 7:17am
Austin-Healy hoods,maybe fenders were aluminum...
Land Rovers were aluminum, least the beds....'highly resistant to sheep urine'
WHY I know this knowledge instead of important stuff is beyond me...
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2021 at 11:06am
Austin Healey hoods, doors, fenders and trunk lids are steel.  It's the rest of the front and rear body panels that are aluminum.  I've restored more than my share of them for others.  I believe the early 100 series Healey's also had aluminum doors.  Many Brit vehicles used aluminum body panels.  Land Rovers have steel frames and cowl/firewall sections. All the rest of the body is aluminum.
I have had several and still have a '72 that we use like a quad around the farm.  Advantage being, it hauls more, has a roof and a heater for winter!!
After WW2, Britain had a serious shortage of steel, but lots of aluminum from re-cycled aircraft.  That is one of the main reasons for common use of aluminum in auto manufacturing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2021 at 4:14pm
Thanks Phil.......... i have never heard that story.. Didnt know that..
Son has a 2000 Explorer 4x4.. Cost $1000.  ... uses it in place of a $15K side by side... Not aluminum, but WORKS GREAT !
Edited by steve(ill) - 02 Mar 2021 at 4:18pm
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2021 at 9:13pm
Does this new Ford have a aluminum box?
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2021 at 5:53pm
UGLY,UGLY,UGLY, Both of them OuchOuch !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2021 at 12:25pm
Actually Freed, I'm going to have to go with OJ on this one, don't look to bad. LOL
I actually have thought the newer 1/2 ton Ford pickups are pretty sharp, but boy them new GMC's sure look good coming down the road.  I've owned a couple Fords but pretty much a GM guy.  After all I kinda owned the company at one time. Wink LOL
This page was generated in 0.891 seconds.
