Thanks for the plow help. |
Roddo
Joined: 16 Jul 2010 Location: Brant, Ontario Points: 466 |
Topic: Thanks for the plow help.Posted: 06 Jun 2011 at 1:43pm |
I bolted on the cover boards and it didnt make much difference. It helped but not much. So i decided to go nuts adjusting etc.
I moved the coulters down and back, set the lift links a bit more so the plow sat slightly deeper on the deadfurrow side. Lastly I made up a 2 ft long landside with a brace on the back bottom. It works mint. I don't even have to look back and check anymore. I hope I can whip this little field into shape to plant some corn before it gets too late! |
Teddy (punchie)
Joined: 14 Jan 2010 Location: Beaver PA Points: 258 |
Posted: 08 Jun 2011 at 4:45pm |
Glad you got it to work, we just planted 2.5-3 acres of sweetcorn today. All new plowed fields, The fieldcorn is all up planted a week ago tuesday and wednesday. Good Luck !!
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
Lonn
Posted: 08 Jun 2011 at 5:40pm |
See what a little adjusting can do. I've heard many over the years say they have that trouble and blame the plow. Some bottom types are a bit fussier than others but as you proved they can be made to plow.
Wink I am a Russian Bot |
Roddo
Posted: 08 Jun 2011 at 8:45pm |
Well I disked the heck out of that little field and planted some corn. I know its late but I don't have any other option. I made a mess of a part of it where the plow wasn't working so well but the rest of it looks great! Again thanks for all the pointers and advice.
