Testing 7000 series tachometer
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Testing 7000 series tachometer
    Posted: 16 Feb 2023 at 10:39pm
Is there a good way to test a tachometer? I fixed some incorrect splicing in my wiring harness, and got the tachometer to work again on my 7080, it looks like it has the correct double pulley on the Delco alternator, and it was originally a Delco system from what I was told. Currently the tachometer reads my low idle rpm is 600, and high idle is 2,200. It is my understanding high idle should be more like 2,800. Is there a way to check and see if the fault is in the tachometer or if something is keeping the engine from reaching the proper high idle?
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2023 at 3:42am
You can get an optical tachometer and put white reflective tape on the dampner on the front of the crankshaft and check it. I cut a piece off the white part of DOT tape like is on trucks. Works great
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2023 at 7:40am
Never used it or have it, but i-phone's have an app to measure rpm's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2023 at 7:53am
get the optical tach.....they are cheap....ebay or amazon 2 yrs ago was $12...used it recently for first time on "new" tractor to check rpm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2023 at 8:56am
That sounds like a good plan! I just checked them out, got one on the way.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2023 at 11:43am
If the pulley is the wrong diameter it will read wrong
ryan
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2023 at 8:19pm
all the grooves in the rest of the pulleys are all worn in after all these years belts all wore in a little  has to change the ratio a littlle bit
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 4:31am
You make a point. That’s one reason I don’t care for these kinds of tachometer drive systems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 9:14am
I wonder what kind of a nightmare it would be to try to drill,thread,mount an 8000 series pickup and wire an 8000 tach? I don't have the knowledge to do it.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 12:16pm
Yup.
When you get your optical tach, just mark the gauge at a couple of the most important speeds. Re-check it every year or so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 1:30pm
I dont see how you could drill the plate on the ttractor. I changed the piickup on my 8070 and it was plenty tight. Im guessing theb 7 and 8000 series plates are the same execpt for the pickup hole but im not sure If you could find an 8000 series plate and change it??????????
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 2:51pm
I figured you could change location (lower?) so long as you "hit" the teeth. Yes it would be a trick to drill/tap same spot. Rt angle drill? I suppose there are some situations (pto) where you need a given rpm but most times you just gas and go!! Dad used to use the shaft tach on the WD to note position on throttle quadrant before using the all crop. Apparently wide open is more than 540? I was very young. Les has good advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 9:05pm
Creston I can understand why you want to be correct. If we run our 390 mower/conditioner at 540 it does a much better job cutting and conditioning. A 100 or 200 rpm off and it makes a big difference on that machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2023 at 10:07pm
My main concern is keeping loaded RPMs when plowing around 2,300. Being as it's a 7080 with a lot of hours, I don't want to let the RPMs climb up around their top rated RPM. That, and I just like everything to work the way it should or it bugs me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 1:53pm
Doesn't that have a Roosa? The one on my 220 has stop screws you can set low and high idle with. If so I'd turn it back to 2600 max.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 2:22pm
After thinking about it the pickup has extra threads. I dont see any reason not to drill a larger holo than the pickup. Tap a plate for the pickup and put oversized mounting holes in the plate. Drill snd tap the engine engine plate for the mounting holes. That way if the hole for the pickup isnt in the right place it could be moved until it worked
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 2:25pm
To clarify thats to put a 8000 pickup on a 7000 series tractor
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 7:07pm
Yes it does, that’s something I’ll look into.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 7:08pm
If this doesn’t work for me, I’ll look into this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2023 at 9:27pm
You say it's high hours. I don't know what that means but if over 5000 and you don't have a history,I'd be putting brgs in the bottom end. You are capable. Just follow directions on the rod bolts. They ran at 2800 and they didn't stay together. The 8070 was turned down to 2600. I set mine to 2500.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 8:44am
I'm not so sure that the 8000 series flywheel sensor will work in a 7000 series. I was thinking that the flywheels were different. I don't think that it reads off of the teeth of the ring gear. Doesn't the 8000 series flywheel have a series of bumps or slots on the front face to give the sensor a reading?? The parts book shows the flywheels to be a common number now, but that maybe just a parts supersession .
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 10:11am
I put an 8000 series tach in my 7050, the pickup reads off the ring gear, I had mine split for PD work so it was easy to drill with the adapter plate off the machine. I located the pickup on the RH side where there is more room, no fuel filter there like on the 8000s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 10:22am
Dakota Digital make a tach and speedometer interface that you can scale the input so the tach reads what its supposed to. Might be the simplest solution.for you Creston
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2023 at 12:34pm
Kevin, good information. Did the rpm read correctly with the original 7050 tach or did you need to get an 8000 series tachometer head?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2023 at 8:10am
Hour meter stopped at just over 8,900. Previous owner said it was that way when he bought it from the original owner, so I’m not sure how many hours are on it. The PO said he only put maybe 100 hrs on it the several years he had it. Someone wrote on the valve cover the valves were set at 9,800 hrs, but I don’t know how they would’ve known that without a working hour meter.
This will be a topic for another thread, but is rolling in bearings really that simple? Will the crank journals being worn out of round not effect that? I just worry a little more on a high horsepower, fast turning engine like this. I do plan to replace the fluid dampener.
Edited by CrestonM - 24 Feb 2023 at 8:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2023 at 8:11pm
Finally got a hand held laser tach and tried it tonight. At low idle the dash tachometer reads 600. Hand held laser tachometer read about 740. Book says spec is 750. When the dash tach read 1,800 the hand held was reading 2,300. So since it’s not a linear correlation, I’m not sure what the issue would be. Alternator belts are good and tight.
Any ideas?
Thanks
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2023 at 8:17pm
Creston, see if you can find a smaller diameter pulley.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2023 at 8:25pm
If it was a linear correlation that might work, but since the difference starts with 150 RPM at idle and increases to a difference of 500 RPM between the dash tachometer and handheld tachometer at 2,300 engine RPM, I’m not sure a pulley would solve it.
This is assuming the hand held tachometer is reading correctly, but based on throttle positions, I believe it is correct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2023 at 5:44am
It is linear: 740/600: 23% off, 2300/1800: 28% off. Close enough to say a pulley that increases the ratio by about 25% would correct the problem, if you opt to go that way.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2023 at 6:50am
I'm with Stan, it's pretty close to linear (probably is linear within reason)  I did 740/600 = 1.233.  1.233 x 1800 = 2220.  Give or take the width of the needle on the dial on the dash, and the math would probably work out perfectly.
