temp gauge |
trace ![]() Silver Level ![]() Joined: 01 Aug 2012 Location: N.W. Iowa Points: 499 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Nov 2022 at 3:03pm |
got a new temp gauge for my 55 wd 45. anyone have any tips for getting old one out safely?
1955 WD-45 WIDE FRONT W/ TRIP
LOADER |
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
Take the hood off so you can get a proper wrench on it mine came right out.
thanks. even bad engineering in them days having to take hood off for want of a bigger access, lol.
LOADER |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21932 |
I've not changed very many but hood off is the first step. Lots of penetrating oil would be a smart second step, allowing it to creep into where it needs to be. I guess a really stubborn one could require some very careful torch heat to loosen the hold. The old gauge is junk anyway, right ? Take a cutting disc and whack off the gauge body to just above the nut and very gently use an impact wrench to very lightly hammer away with a six-point socket. This of course after using liberal amounts of penetrating oil and letting it soak.
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5236 |
I must have got lucky, mine came right out on the CA and the WD. I used Kroil and let it soak overnight.
Dennis J OPKs ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Overland Park, Points: 533 |
It's been a while but as I recall soaked good and then used a good Vice-grip and may have even used that trick of slight tightening it and then backed it out. I'm pretty sure it was an original on a WD 45.
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 980 |
My wd one came right out, but I had the tractor running before it did it…
JimD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mounds, OK Points: 2116 |
I've always done like Dr Allis said and cut off the stem. Soak them good and put a socket on it. If I have to save it for some reason I would probably try a line wrench.
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543 |
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4091 |
I've changed two or three of them, don't think a line wrench will work, had that thought. What worked for me is a knipex tool, called a pliers wrench. Kind of a cross between a crescent wrench and a pliers. Your mileage may vary. The Dr. has a good plan.
