Tearing apart my 1944 Allis C
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2010 at 12:02pm
I did pull parts of the governor and other rather large pieces of metal out of the oil pan when I took it off. I did get the gear teeth from the part I replaced out of there.  There didn't seem like there was any problem with the oil pump as I was getting oil to the rockers when I cranked the engine. Guess I will be taking lots of pictures and have lots of questions really soon!
As Pumpkin Man said in another post... I just need to get started and see what I find...
But that won't be until Friday
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 12:25am
Miles, Did you get the head off and see what there is to see?  Just gotta know!
Allis Express participant
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 4:57am
I would take the head off to check valves and pushrods before I did anything else. If I understand correct you've got the cam gear timing resolved so I see no reason to believe there's anything wrong with the bottom end at this point. If there is a problem with the bottom end get an engine stand and pull the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 8:28am
John, I'm still in Denver and haven't left yet. I'm getting some heaters together so I can work on it out in the shed and hopefullly fix it without having to remove it from the tractor. If I have to remove it, then I have been told I can bring it inside the house!
Miles Gray (CO/KS)
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 8:43am
Best two places in the house is in the center of the dining room table where you have plenty of room on all sides to lay parts and tools. There you can move around all sides to better see all the problems. The other  place is with the engine on an engine stand in front of your recliner where you can lean back and watch TV while you are thinking about the next move. Just make sure you have a sturdy stand on both sides of the recliner to hold the tool box and parts and large free turning wheels on the engine stand so you can push it to one side when watching th TV. Also easir for the wife to clean up the droppins from the rug.
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 8:49am
I sorta like the kitchen table that way I don't have to walk too far to put the parts in the dishwasher.
Bob, North Carolina
1949 B
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 8:53am
Based on what you just said, Dick, I'd put Dixie on the same level as Mother Theresa!
are genuine." - Mark Twain
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 8:56am
Youll also be close to the oven to dry parts if you put it on the kitchen table.
Not to worry Miles, we won't get you in too much trouble. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 11:19am
And if you decide you need a snack, what better place to be than the kitchen?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 12:05am
Miles, It never ceases to amaze me as to how helpful the members of this forum are!  I had never even thought about using the kitchen, and I'm single! (Perhaps that is why!)
Anyway, have fun, where ever you do the work.
I pulled the head on my B this evening, took all of half an hour.  Spent another hour cleaning the dirt and wasp nest out of the cylinders.  Maybe it didn't have spark plugs in it for 20 years or so.  Two cylinders don't look too bad the middle two are about 1" down from TDC and are a bit rusty.  Haven't been able to drive them down.  May pull the pan and rod caps and try one at a time.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 10:26am
Those rusty cylinders will be easier on the rods, crank, and block if you take off the rod caps and pull sleeves too, then go to the hydraulic press, but figure on having to replace or remachine parts.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 1:26pm
I'm actually going to put plastic down and then a canvas tarp to catch all the drippings, I use my laptop computer with a wireless connection to watch TV so I can move it around easier than the engine on the stand. My only problem is the off-sized front door that I have to get the engine stand through.
Miles Gray (CO/KS)
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 1:28pm
John, have you tried just  putting the 50/50 ATF/Acetone mix on top of the rusty cylinders and just letting it sit?
Miles Gray (CO/KS)
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 9:47pm
Miles, I tried the mix a couple years ago on the all-crop engine and it didn't work, at least not yet.  I'll probably pull the head on that one sometime and check it out.  The exhust has aways been covered and it had been stored inside until I got it.  I suspect it is tight from sitting since at least 1983, when the owner passed away.
My plan for the B and C is to pull the best cylinder out of the B and put it in the C and get an engine kit for the B.  The B is rare in that it has a adjustable wishbone front end and the C has a single wheel front end.  I also have another C which I have misplaced the rods and pistons during a move.  It will be a parts source  for the other C and B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 9:48pm
P.S. Have you gotten into your engine yet?
This page was generated in 0.053 seconds.
