TaylorMade R9 Irons
hehegolfssss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hehegolfssss Quote  Post ReplyReply Direct Link To This Post Topic: TaylorMade R9 Irons
    Posted: 30 May 2011 at 3:02am
r7 vs r9 irons shows some advantages of r9 irons. Like the r7, the clubface of the taylormade r9 irons for sale uses the inverted cone technology on the inner side of the clubface for consistent ball speed on off-center hits. Using that as their foundation, the new TaylorMade R9 Irons 3-9PS long and mid irons were designed separately from the short irons to optimize performance in each club.
The 3- through 6-irons house a fully enclosed, foam-filled compartment located directly behind the clubface and beneath the cavity badge. TaylorMade refers to this chamber as the "Velocity Control Chamber" because it is meant to create a higher launch angle, more power, and optimal feel. Moreover, Golf Clubs for Sale the weightless soft feel foam allows the engineers to have an ultra-thin (2.0 mm) face that wraps around the topline and leading edge. When the face flexes at impact, it is meant to act like a thin-faced driver and result in a higher CoR, faster ball speed, and added distance.
The virtually weightless foam originates as a powder that is sealed in this chamber, and then transforms into a foam substance after the clubhead is heated during production. All at http://www.24golfstore.com/ 20110530
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 3:09am
Some gopher posted this.
Reported.
This page was generated in 0.049 seconds.
