Tap&Die for D14 steering wheel nut
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Topic: Tap&Die for D14 steering wheel nut
    Posted: 26 May 2011 at 1:21pm
What size tap and die do I need for the steering wheel nut on a '60 D14 with power steering? I boogered up the threads on the neighbors from smacking it with a hammer. I had the nut on but everything was froze so bad I hit it hard enough to mess it up anyway. Its enough that I cant get it started now. Thanks for any help.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 3:44pm
You won't be able to start a die to match the threads if you have mushroomed the end of the shaft. A thread file will let you match the threads. My wild guess is that the threads are 20 or 24 pitch. Thread files come with 8 pitches per file so it only takes a couple to fit most US threads. You can get there with a small triangular file but it takes a lot longer and a great deal of skill to make a good thread again.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 4:51pm
I didn't mushroom the end of the shaft. I had the nut on the shaft. I hit it so hard I messed up the first threads on the nut and shaft(I hit it in the wrong spot while beating and made the nut go sideways on the shaft).
I need to know the correct pitch before I go to the store to get the tap and die. Thanks.
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 5:03pm
A tap cuts internal threads. A die cuts external. You only need a tap, prob be cheaper and less trouble to buy the nut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 5:18pm
I need a tap and die. It messed up both. I might would be able to get a new nut to start though. Where would I get the nut without ordering it? Its not very tall.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 5:31pm
Measure off 1/4 inch of full threads on the shaft and count the number of threads in it. Multiply that number by 4 and you'll know how many per inch. If ya don't have a lathe any machine shop could find or make ya one the right width.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 5:33pm
As far as the shaft thread. Do the file thing. You'll get more use out of it then that particular size die.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 8:49pm
I messed the shaft up on my 14, so I took another nut, cut it in half, sandwiched it around the shaft , held it together with a pair of vise grips then turned it off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 9:55pm
I never would have thought of that. May try it, gotta get another nut first.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 10:13pm
if it's any help, the hex nut for the later D17's is
13/16-20
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 10:20pm
Measure the thread dia of the shaft then pick the NF (national Fine) thread for that dia. Then you have it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 10:23pm
Like Gerald said, a die would probably not do you any good. If the first thread is messed up, and you get the die started it might not start at the same point the original thread started. If the die doesn't start at the same point the original thread started, you will have a mess of unusable bumps on the end of your shaft.
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 6:23am
Nuts we have in stock,they are 13/16-20 UNEF and cost $5.00
If you are going to replace the steering wheel anyways do all your hammer work and bust off all the rubber/plastic the head with torch and drive off hub. you can hacksaw off 1/8" of the damaged threads (No more than that) and clean up the threads with a thread file or a diamond file one thread at a time. David  www.djstractorparts.intuitwebsites.com
734-320-3470 if you have any questions
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 6:42am
There are thread chasers made for that that work the same way but your way is much cheaper. May not be as hard of material but if it works it works.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 11:01pm
I had the steering wheel off already. We did tear up the old steering wheel getting it off(he ordered a new one anyway) I had everything apart to paint and had to beat on the shaft to get the u-joints back on and a new pin through them.
I'm gonna see if any parts store loans tools so I can rent a tap and die.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 12:16am
They aren't going to have that size tap and die. Look at McMaster-Carr www.mcmaster.com and be seated firmly when you find the price. 13/16 isn't a standard diameter and 20 pitch isn't a common standard thread except for spindle nuts. And the die won't work on the bashed threads and a nut is much cheaper than a tap to clean up the nut you have.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 12:25am
If the new nut don't work I guess I have to buy a new shaft which is going to set me back. I'm not getting paid enough for this job as it is.
BobDinNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobDinNC Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 3:31am
The D10 is 13/16-20.  I ordered the die from Snapon Tools online for less that $12 including shipping.
This page was generated in 0.178 seconds.
