TA46 On An 8070
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: TA46 On An 8070
    Posted: 23 Dec 2016 at 3:37pm
A good friend just called with an 8070/TA46 Westendorf question. He wants to know if anyone has a set of side hoods that have had some cracks in them. He tells the side hoods are a little to wide and would like to cut them off above where they flair out. Just above the stripes.
I told him NOT TO CUT them until we talk again. He has prefect ones on it now. What have any of you 8000 series/loader guys done with the side hoods on your tractors?
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2016 at 4:38pm
We have a set of beat up ones.  or he could just leave them off when loader is on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2016 at 10:32am
Can you post a picture or two? And Merry Christmas.
JCFarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2016 at 8:40pm
My TA 46 came off an 8070 and fits my 8010 just fine. I wonder how his mounts are attached to his tractor?
KY poorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY poorboy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2016 at 9:32pm
We have a TA 46A that came off of a 8070 fwa. We put it on a 7040 and had to get 7000 series brackets so we didn't have to cut the side panels. We could have made the 8000 series brackets work if we cut the side panels, but I just didn't want to do that cause the 7040 is still all original paint and metal, and pretty nice for a 40. He may need to get the brackets for the tractor, or do some cutting and welding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 2:05pm
KY poorbay, would you still have the brackets from the 8070? I haven't seen there setup yet. I have a TA46B on my 7045. I might have to take it over to the 8070 and park them together and compare.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY poorboy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 9:59pm
I traded them to tbran on here for a new set. He owns B&G Equipment in Paris, TN. I would think he still has them, it's only been 5 or 6 weeks I think. They are in excellent shape.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 9:08am
Right side isn't too bad but left is pretty beat up.
Edited by Jordan(OH) - 07 Jan 2017 at 9:09am
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 11:43am
Them panels and grill have seen better days
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 3:20pm
Them ain't bad at all. Very easily fixed because of them being fiber glass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 6:45pm
This is more of bump for a friend than anything, but, what kind of red engine is under the hood with a starter on the right side?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2017 at 7:45pm
It's a CIH cotton picker engine, aka, 8.3 Cummins.
Well maybe, if you know fiberglass.  I can weld steel but don't know a thing about fixing fiberglass.
Transaxial View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Transaxial Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2017 at 3:50pm
What do you do for a bell housing and torque limiter setup? I think there is someone that sells a conversion kit or did you make your own?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2017 at 8:55am
There is an adapter plate. The flywheel is a new part from Cummins but machined to fit torque limiter. I can get you contact info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Transaxial Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2017 at 2:02pm
Thanks for the info Jordan. I am not looking at doing one immediately but just for future knowledge that there is a simple and proven way to do it. I would think it would make a really nice unit with that engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Transaxial Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2017 at 2:21pm
I have a 8070 MFWD and have a Ezee-on loader on it that allows the side panels to fit normally. As far as fixing those fiberglass panels, it is not very difficult to do yourself and they will look like new when you are done, just a little thicker! Bonus. Or take them to a body shop. Naw, too expensive. Get some different weights of fg cloth and then some resin and hardener. Two part catalyst type resin. Do not mix up more than you can use in 10 minutes or so, and just start laying on layers of reinforcing cloth on the back side. Let them set and then do another layer until the panel is good and strong. If sections are missing of the original hood just remake them using cloth and resin. Make sure you soak the cloth all the way through with resin. For the front side, fill little crack lines with resin to overfull and just sand off the excess when done. You can use a little skim of bondo to finish any rough spots before painting. There are lots of good videos on youtube. It is amazing how a few hours and a little bit of materials can rebuild a pretty ugly old panel, and make it look like new.
The site will not let me upload the pic of my 8070 because it already exists in this forum so somewhere in here is the pic of my 8070 with loaded brackets on and hood fitting.I found the pic of my 8070 under Paint Codes
Edited by Transaxial - 29 Jan 2017 at 3:17pm
