Swathing a couple years ago
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: Swathing a couple years ago
    Posted: 16 Jan 2011 at 9:50pm
No fertilizer or weed spray and it shows but at the time it was more for fun. It's an early Owatonna Model S 10 foot. Very wet field too.
Edited by Lonn - 16 Jan 2011 at 9:55pm
Wink
I am a Russian Bot
Matt (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 3:48am
cool looking machine!  bet it can get a little hot though on that seat.
1955 WD-45 with factory PS
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 4:17am
There's nothing quite like a swather, I mean that as a joke.  We get to do plenty of swathing around here, at times it's fun you laugh at all the more usefull things you should be doing, or just hope that none of your friends see you.
John Deere started to build a helicopter, but failed and ended up with the 800 swather.  I've had the displeasure of working on some.  It's really a blessing when scrap is high.  A friend was cutting with one and seen a large burdock, now what can a burdock do to a swather?  It knocked off the belt driving the reel, which in turn wrapped up and broke a chain which wrapped up, in turn breaking a gearbox.  An unfortunate chain of events.  At leas it gave us something to have some beers over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 5:22am
Did you mean that, about the 'chain of events' ?  LOL
Harvey/pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 7:05am
 You should contact the guy on Dirty Jobs, looks like it would qualify for first cutting about Aug 15...Harvey
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 7:33am
If there is a breeze it's not that bad but if there is trouble you really start to sweat just thinking about it. A simple machine made complicated. Dad always said Owatonna and Gehl must have hired all the rejects from Allis as most Allis equipment wouldn't be that hard to work on.
Wink
I am a Russian Bot
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 8:18am
Still trying to figure out the Swathing angle, wouldn't a combine do what is needed? I mean why swath only to come back later and pick up the windrow? Does it separate that much weeds?
Charlie
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 9:05am
With all those weeds, when cut with a swather and let lay for a few days the weeds dry and the oats/grain combines/harvests much better.
Dusty
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 5:42pm
Dusty
And you have a bigger harvesting window. You can cut just a tad earlier than a direct cut and let dry. Do the big custom harvesters still do any windrowing of oats and wheat?
Wink
I am a Russian Bot
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 7:51pm
wow, that brings back memories......nothing worse than swathing rusty oats....other than combining them with a JD 95...
Thanks
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2011 at 8:01pm
  YOU GUYS DO NOT KNOW WHAT DIRT IS??  WE USED TO BALE SOYBEAN HAY WITH
   A  CASE NCM BALER AN TIE THE WIRES BY HAND SETTING ON A SEAT ALSO GOT A WHIFF OF DIRT EVERY TIME PLUNGER HIT  100# WIRE TIE BALES  ONE OF THOSE RESTORED IN SPARTA ,ILL IN THE A-C MUSEUM!!!!!  WIRES WERE STUCK BY HAND THEN 1945 AN LATER
This page was generated in 0.054 seconds.
