Swapping govenors on 226 motor
KurtDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Topic: Swapping govenors on 226 motor
    Posted: 24 Mar 2010 at 8:24pm
What is involved in changeing the govenor on an E combine 226 gas engine to be put in a 170 gas tractor? I assummed I needed to swap govenors as the combine motor does not have the throttle shaft connection point to the throttle cable in the govenor cover.
                                           Thanks, Kurt
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2010 at 8:34pm
Change the front cover and weights and spring and you will be fine
Albert
