Sustainable Farming
Leesok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leesok Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 8:03pm
I have ground and mixed feed for 60 cows for the last four years with a 37 uc with rear steel. Can operate all controls from the ground without climbing in and out of a cab. Has always started on 3 or 4 pull without being plugged in like newer tractors. Have not bought tires, battery. starter or ect. Usually takes about 40 to 50 gal fuel per year, stays hooked up except to go to local show to pull threasher. These old tractors still have their places on the  farm you just have to find it.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2011 at 9:12pm
I just read an ad for a "green Machine " that burns 11 gallons of desiel and hour.
I can run for hours with the D-15 on half that amount. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 9:50am
I used to run a Green tractor for a guy that burned 10 gallons an hour too but I can guarantee you that you won't pull a 17 1/2 foot chisel plow through 10 acres of stalks in an hour with your D15.
Italy Hill Produce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 10:50am
The problem with the original post is that there are too many definitions of sustainable. and no official definition. To me it means feeding as many people a complete meal on as few acres as possible with as few petroleum inputs as possible. Yes we run fuel in our tractors/gator/and truck. but no petro chemical fertilizers/pesticides etc.
I grew up on the family's 170 acre 6th generation farm. It has been every type of farm over the years and in the 70's my parents planted grapes and started a winery in 81.  Now the winery is in it's 30th year and my wife and I have started a produce business and are in the process of certifying 25 acres Organic for the veggies.
One thing that is constantly brought up that bugs me is "how are we gonna feed the world without higher yield per acre"
Food is not 1000000 acres of cow corn. or 100000 acres of wheat.
Food is 2-10 acres of mixed veggies, and specialty grains. which is the exact role for an allis G and an all crop.   Ideally you need 3-4 plots with a 3-4 year rotation. 1 year veg crops, 1 year grain crops, 1 year fallow/grazing, and 1 year green manures.. That is what we are setting up for our small business. We feed dozens of families on a handful of acres via the farmer's market.
One thing about certified organic, is it is alot of paperwork, but it really isn't bad. And it does require learning, and it does cost some $ but you make it back quickly Also the 3 year transition period is very do-able.. You don't have to transition your whole farm at once.
The whole concept of certifying organic is completely ass-backwards. You should have to pay and keep tons of records to USE chemical poisions and artificial fertilizers. Being organic should not be a thing that requires certification... Once the soil is healthy, the crops are healthy.  My dad is the perfect example of a "conventional" farmer. He said when we started doing veg crops in the old hay field "that should be very good soil, we've been putting ammonium nitrate on it every year for 30 years"  And my wife and I looked at each other shaking our heads.. The soil was compacted, the organic matter was low, the calcium was low, all the nutrients were low... the PH was low.. etc.. 2 years later, the OM. is up, the nutrients are balanced, the PH is up and we've greatly reduced the compaction.. I actually sunk the 2 bottom mold-board plow almost out of sight last week. The first time I worked the soil it only went about 3-4 inches down!
Adding chemical fertilizer to soil is like raising a kid on pepsi alone.. Sure he'll have tons of energy right after you apply it, but it will be gone in a short time and you'll be worse off than when you started.
I use cow manure from a local dairy, that I compost myself with a big front loader to turn it. and I mix in all the grape pummace from the winery.. This is obviously not do-able for everyone but our soil was in really rough shape when we started... Now there is certified chicken compost available and many other options in our area.
So we are slowly becoming sustainable in as many ways as we can. The main thing is to source your food LOCALLY and as sustainably as possible.
That is the definition of homeland security.
Jonathan
G tractor and an All Crop 66
Also Kubota MX5100F and M9540HD12
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 1:05pm
Natural gas is mostly methane. The demand for natural gas has been rising rapidly because it burns fairly clean and is used for power plants as well as for home and industrial heating. Its a pain to compress it to liquid to get a decent range from a vehicle though there is much NG compressed to liquid and shipped by tanker from Australia to China.
Methane can be created by decomposing crop residue mixed with manure and is. It takes a large scale facility to make it totally practical (e.g. cheaper than buying fuel), and is being done on some of the larger diary farms. Its also a product of covered land fills, again it takes larger scale to make it useful but some landfills in the Chicago area have been collecting methane for years and using it to run engines turning generators to produce the power needed to process garbage into the land fill and to have a little left over to sell.
Remember organic farming was defined by Robert Rodale, without benefit of input from science, regulators, or engineers. The principles of organic farming ignore the facts that things coming from the ground (like directly mined phosphate rock) require acids or acidic soil to show a crop benefit and the factory acid processing is quite effective at cleaning out things like heavy metals that are not a benefit when added to the soil.
There is much use of manure anywhere there are confinement facilities for turkeys, chickens, pigs, and cattle. I can see piles of composted turkey manure around here in the spring and see the honey wagons delivering hog manure liquid spring and fall. There is some compaction in the fields from those 125,000 pound tractor and honey wagon assemblies and there is much more water than nutrient.
There is much discussion over on New AG Talk (the best farm page) about cover crops, strip till, and no till all of which save on fuel use and often lead to better crop production on any scale. One of the participants, Steve Groff, is known around the world for use of cover crops.
Commercial agriculture is not static, it is changing all the time driven by demands (its demand and some speculation that is driving high commodity prices this year), and high input costs. No farmer that I know is blindly doing the same as last year because the costs of seed, herbicides, insecticides, fuel, and fertilizer are going up like crop prices, sometimes much faster than crop prices. And no one sells the whole crop at the highest price we spread out those sales because the only way to know a peak has occurred is after the fall from that peak. I have 3/4 my anticipated 2011 crop sold, for a peak price of $6.10 for corn but an average price of 5.10. I'll make out fine.
There has been a discussion on New AG Talk about sustainability but the first step has not been resolved, that of defining what sustainability is. Then events like spring floods come along and destroy big chunks of needed prime farm land (as well as urban sprawl) making it harder to keep up the total crop production the world wants.
In the past, solutions for overpopulation of territories have been major wars, with the most overpopulated countries attacking their neighbors to get control of more land. Its been a longer period of major war since WW2 than ever before in history. Maybe its because of the devistation that could be caused by a nuclear blast that keeps those desiring more land in check, maybe its the relative prosperity much of the world is enjoying even with the recent market collapses.
If wars don't cut population growth, and population growth overtakes technology for better crops and overruns crop lands, then starvation can control population growth.
I'm not so sure the under developed lands of Africa are rich, I suspect they have been farmed over the millenia without putting back fertilizer until they need a couple tons of N, P, and K per acre to grow significant crops yet the politicians are rejecting outside knowledge, finances, and materials (like fertilizer and modern seed). To say nothing of the need for organic material in the soil.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 1:08pm
Local food production is a fine concept, but north of the Mason - Dixon line we have winters, and sometimes cold springs that definitely inhibit the growth of all crops. Garden crops tend to not store well for long periods, at least not tomatoes, lettuce, and the like.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 2:29pm
"Local food production is a fine concept, but north of the Mason - Dixon line we have winters, and sometimes cold springs that definitely inhibit the growth of all crops. Garden crops tend to not store well for long periods, at least not tomatoes, lettuce, and the like."
Gerald, no offense, but you are just regurgitating the same stuff that is not even close to correct.
I Live in upstate NY, I eat about 95% locally year round. We obviously buy things like sugar, olive oil, citrus etc.. that we don't  grow. But 99% of our fruits and veggies we either grow ourselves or buy from other local farmers within a 20 +- mile radius.
And it is not hard to do it ourselves. We grow chiccories year round, We are still eating last year's kale. We have been enjoying popcorn and polenta from our own corn. We bought a whole pig from a fellow market farmer, we bought half a cow from my highschool Ag. teacher (2 miles away) we raise our own broiler chickens and sell them, and we have 4 chickens at home from whom we get eggs year round.
My wife cans piles of tomatos we have root veggies from mid summer through spring, garlic, hell I still have a few crates of onions in the cooler and winter squash in the back room!
yes you can't grow icerberg lettuce year round in upstate NY, but who eats that stuff anyway? It has no flavor and virtually no nutritive value.
You need to read the book "Four Seasons Harvest" by Elliot Coleman, He farms year round in Maine.
Jonathan
indiana2door View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote indiana2door Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 4:34pm
There are two kinds of crazy...horse and organic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 8:25pm
wow a nonsensical statement that lacks any sort of fact, reference or bearing on anything.
Thanks for adding.
Jonathan
Ps I do agree with you on horses... :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 8:30pm
BTW people survived north of the mason dixon line for hundreds of thousands of years before sysco and mcdonalds.
Also the term "conventional" that describes farming with synthetic pesticides, is actually the NEW method of "farming" and Organic is actually the form that has been around since the dawn of man ;)
Just food for thought...
Jonathan
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 9:35pm
Jonathan-  I don't think Gerald was saying that one couldn't preserve summertime harvest for wintertime consumption-  My ancestory founded a town a hundred miles northwest of Gerald, and survived just fine doing the same sort of canning and preservation I do, and I'm sure Gerald does it too.
I think what he's saying, is that it's asking a bit too much to expect sensible production capacity of cash crops from land that's frozen down 48".  My greenhouse can grow quite a bit, but some things just won't produce well when the seasonal extremes (sunlight hours included here) are that far out.  There's good reason why the California farms, even with miserable produce taste, are still profitable... because tasteless sliced tomatoes are better than no sliced tomatoes.
But I'll echo the request for clarification on the definition of 'sustainable'.  The term is so vaguely applied to many things, that the definition needs not only to be drawn out, but also identified as to where, how, and to what extent, 'unsustainable' is occuring.  Clearly,  the California gardens are a good example of how incredibly beaten soil can continue to 'produce'... and they just keep doing it... much to the detriment of taste and nutrient level, as well as drawing down the Colorado River.  Seems to me, the whole reference to 'unsustainable' comes from people who focus on one part of the world, and little, if any, of the rest.
If a purist formula for 'sustainable' is necessary, I can hack it down to a very simple level:  ALL the energy that the earth has... regardless of it's form, is the result of solar radiation.  To be purely 'sustainable', one must establish a DAILY budget based on the maximum amount of SOLAR ENERGY that they can 'capture' PER DAY.  Anything beyond that, by definition, would be 'unsustainable'.  I think that's a bit extreme, but SOMEBODY has to play the Devil's Advocate here.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2011 at 11:01pm
Frankley "sustainable" means something different to everyone. Some would say breaking the prairie sod and farming the same land continously, and profitably, for over a hundred years and several generations is proof enough that what they're are doing is sustainable.
To some, poking a hole in the ground with a stick and dropping a seed in it by hand is the only sustainable way to farm. To another, farming the maximum number of acres with the least possible labor and the lowest cost per bushel modern technology allows is the only sustainable way to farm.
I think history has shown us that low costs and high yields win the sustainable contest. The problem is how you arrive there isn't just one easy answer.
AllisUpstate View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 6:26am
I agree that Sustainable as a term means different things to different people, as opposed to Organic.  The fascinating thing to me about farming is how deeply complex an operation it really is.  Around us, too many farm the same way I saw growing up as a kid, which is essentially to sterlize the soil and rely almost totally on synthetic fertilizer and herbicides for production.  On the hilly land upstate here, that production method can be a disaster in terms of erosion.  Also, costs are totally dependent on the costs of petroleum and the profits of the large agro companies supplying the input materials.  The result is a loss of independence, both individually as a farmer and nationally.  It is sustainable only as long as the world has cheap petroleum or other energy sources, and the soil isn't totally washed away.
My eyes have been opened over the past 10 years or so as I have read all the books I could find, and finally start to understand how soils and plants truly work, as an incredibly complex living synergism between fungi, bacteria and the the plants.  To me, understanding how that natural system works would allow me to harness that energy to build a farm that would continue to thrive despite the price of oil.  Granted, operating the farm machinery requires oil - which eventually we should be able to provide using biomass and perhaps direct solar conversion to liquid fuels - but the real energy hogs on a farm are not the tractors, but the synthetic fertilizers and chemicals.  So sustainable to me at least, means trying to better understand the natural systems, so that I can reduce energy inputs from off the farm, and improve the soil health and reduce erosion, such that I could imagine the farm becoming more productive and independent each generation, rather than less.  It doesn't have to mean a purist definition of Organic, but it does mean bending the curve away from Monsanto and Sysco, and more towards understanding and harnessing the natural systems on the farm.  For me at least, Sustainability is almost synonymous with Independence.
Our beloved Allis tractors and equipment relate to this thread, as really well-designed equipment, that can be restored and continue to provide the same service as their original design, almost indefinitely with proper care.  They represent recognizing excellent design and build and utilizing it, rather than throwing something away just because newer, more expensive technology is out there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 7:15am
Hey Allisupstate: where in upstate NY are you? I'm on keuka Lake.. but I'm heading over to a NOFA NY meeting and field walk in the Ithaca/trumansburg area TODAY starting at noon..
If you are not too far away, it's like $15 if you aren't a nofa member..
hth
Jonathan
D17JIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 8:45am
I see a lot of news and talk on organic production.  If we can work it out so the Billions that live in NY and Chicago and LA and many others can have stored organic foods year round then it might work.  Of course the manure needed will have to come from organic livestock farms or we may not have the manure since we will no longer be eating meat (what many want us to do).  That would take another total cultural change.  I have a daughter in Seattle and went with her to the open market (very Large) and saw only one organic produce booth.  Not a pretty sight compared to the others.  I know they are not all that way but it turned us off at least that day.  There is a lot to work out before this is the only way we farm.  It's a lot easier to  at at the local level than world wide.  Good luck !! (and  I mean that seriously)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 9:32am
I think there are too many issues to address in one thread, There are too many interesting directions to take this in.
As far as sustainability is concerned You have to state what type you are shooting for..
If all you care about is being financially sustainable then you have to specify if you mean with or without subsidies.. Because if you ask me, If you farm 10,000 acres of corn and soybeans on the increadibly fertile soil in Iowa, but you can't make money without subsidies (See the documentary "King Corn") then you aren't financially sustainable.
If you mean sustainable in the petro chemical form, then you have way more work ahead of you, because you can do many things to cut your dependance, but that all depends on how dedicated you are.. Yesterday we visited a farm that uses horses for tillage and they had to give in and buy plastic wrapped high tunnels, which was a hit to their petro sustainability, but they had no option because they had to first achieve financial sustainability..
We are not THAT dedicated to the petrolium sustainability, IE I drive a chevy truck, my wife has a TDI jetta, Yes it uses regular diesel, but it gets 50+ MPG.. I would love it if GM/ford/dodge etc.. Would offer more than one diesel engine.. I want a half ton truck with a small diesel engine (something comperable in power to the 4.8L V8) So that instead of having a 6.6L duramax, with ungodly torq, and 15-18 MPG Perhaps I could have something with adequate power to haul the truck and my produce around that maybe gets 20-30MPG Right now the only option is a sprinter, and they don't make them with 4X4 and an open bed..
OK getting off topic..
We use plastic mulch and drip tape in our organic veggies. BUT we don't use any synthetic fertilizer or pesticides.. Our natural enemy populations are HUGE and our soil fertility (both the living and non-living components) are thriving.. Which makes the plants VERY resistant to many diseases and pests.. And more importantly the vitamin and nutrient content of our veggies are far better than that of conventional ones.. Not to mention we add things to the soil to improve the flavor even more.. Did you know that tomatoes actually TASTE better when you add a small amount of sea salt to the soil?
Jonathan
