Surplus Record . Com
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Topic: Surplus Record . Com
    Posted: 07 Nov 2020 at 12:16pm
Guys I found this site while looking for forklift info. I entered Allis Chalmers. They have something called Ball Mill and Sag Mill. I have no idea what they are. But it says they have 3000 HP? Dont tell Shameless, he'll have one of those dang 3000 HP motors on his dang old machine, world global warming will be over. Heck he'll have the equator covered in 6' of snow.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 12:48pm
everyone has heard of a grain mill where you grind grain... A ball mill is a TYPE of mill used to grind coal at a power plant.. You have a BIG BOWL like a soup bowl but 6 - 10 ft in diameter. You put in  a dozen "balls" that look like steel bowling balls... You rotate the bowl with a motor and the balls roll around inside.. You dump crushed coal into the bowl that is 1-2-3 inches in diameter.. The balls crush the coal into powder. This all happens inside a box with a blower fan on top causing a vacuum.. The "coal dust" gets sucked out the top as more coal is added to the bowl.. Constant feed and extraction.. You can run several tons per hour thru them..
Edited by steve(ill) - 07 Nov 2020 at 12:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 1:10pm
Had mills as that at the Power Company dirt burners, actually used Barrels of misc diameter steel balls all rolling in the coal to beat it into powder, that would be air blown thru ducting into the furnaces.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 1:13pm
and a SAG mill is a SUPER SIZED Ball mill... Big as a 3-4-5 bay garage... Grind a variety of WHAT EVER...
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 4:58pm
They also used ball mills to grind precious metal ore. The balls could be as big as a grape fruit and small as a quarter. I hauled them out of KC to south Mo for the mines down there. The large ones were heavy as the dickens.      Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 5:38pm
[TUBE]NulDDkljI7o[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 8:39pm
you spose i could plug one of them into an RV outlet?
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 8:41pm
ball mill
[TUBE]aVQ9B3LtCPk[/TUBE]
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 9:23pm
So, then I take it the coal dust is highly flammable?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 10:23pm
YES... a "coal mill" is a little different than the above movies.. The coal is ground into a very fine powder. The atmosphere inside the mill has to be maintained so it is out of the Explosive range.. There is a big exhauster fan that SUCKS the dust out of the mill and forces it thru tubes into the blast furnace ............ at a power plant....... Everything is normally computer controlled these days.. Cuts down on the explosions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 10:27am
The coal dust is blown into boiler and the amount controls the heat output of steam to run turbine for generation . The result is also no buildup of unburned coal and just a coal s-lag is the result along with fly ash which is saved to use as a additive to cement in making concrete. (posalone)
 the s-lag is separated and graded as roofing shingle particles and as blasting materials for sand blasting media .
Edited by Coke-in-MN - 08 Nov 2020 at 10:30am
This page was generated in 0.077 seconds.
